Results 1 to 19 of 19
    Oct 27 2007
    2001 Golf 2004 A4 USP
    In the lab
    Fitting wide ass tires, this ones for you Jim!
    I have a set of HRE 526's, 18x10 and 18x8.5.
    They clear the uprights and I'm going to a larger lip on the front so it will be 18x10 as well, widebody is in the works...
    What tire sizes can be worked with the stock hubs/uprights?
    Mar 09 2004
    99.5 A4 Avant, 01 allroad
    nw michigan.
    Re: Fitting wide ass tires, this ones for you Jim!
    Just sent you this as a PM...
    This car really inspired me. It runs 285/35-18 Pilot Sports on 18x9.5 et20 Rota wheels. The height won't work well on a B5 so a 285/30-18 is the way to go. The overall height has to stay very close to stock.
    Jim
    I Do Werk.
    Mar 09 2004
    nw michigan.
    As far as tire fitment problems go, this is the bitch of the bunch. The curvature of the rear upright dictates the tire height relative to the inner sidewall. Go taller and out or stock size and stay tucked.
    245/40-17 Yoko Guardex on 17x8 et35.
    225/50-16 Sumi HTR 50Z on stock Swings.
    This tire is almost exactly the same height and width but the wheels have a different offset placing it just a bit closer to the upright. That clearance disappeared in a hurry.
    Jim
    I Do Werk.
    Jun 04 2007
    01' A4 1.8TQM;15' Wrangler
    Austin/DFW, TX
    Im running a 245/35/18 on a 18x8.5" with a ET35. I am SOO close to that rear upright its not even funny.
    That allroad is the sects
    BetaAlphaTau Member #12
    01' A4 1.8TQMS 5spd swapped
    My 5-Speed Swap DIY
    - B6 USP
    Oct 27 2007
    In the lab
    The thing is, I don't mind going out to clear that rear upright...
    Veteran Member Four Rings zrowcool's Avatar
    Nov 09 2006
    2000 B5 A4 Quattro / 00 F-150 XLT S/C
    Bronx, NY
    yeah thats a lot of rubber on that allroad. Has anyone tried to either bend that upright or fab up another one? It has a really odd curve and looks like there plenty of space if it curved a bit wider. I know im not comfortable with the engineering involved with suspension but looks like a plausible idea and im sure like everyone who wants to ride wider wheels would buy it.
    2000 A4 1.8tq
    Running only on Amsoil fluids.
    Amsoil products at wholesale pricing... Ask me how!
    Feb 27 2007
    Chicago
    that allroad it sick looking. Where did you find those pix? Custom order wheels?
    97 A4 2.7T OEM RS4 Widebody 6-speed
    01 S4 2.7T Imola Avant 6-speed (Sold)
    90 Coupe Quatrro 20v (Sold)
    Veteran Member Four Rings ghost6303's Avatar
    Nov 03 2008
    98A41.8TQM
    if your going to be messing with the geometry of that piece you really need to understand what the change will do to the entire suspension. you would have to get the angels perfectly symmetrical on both sides while keeping forces on the joints/pivot points the same. it could probably be done but isnt something you could do with a hammer in your garage.
    Veteran Member Three Rings big_greasy_taco's Avatar
    Apr 28 2008
    Houston, TX
    Bending the upright would destroy the entire rear suspension geometry.
    If someone had the time and machinery it would be feasible to make a new upright. As long and the angles of the ends of the upright remain the same in reference to each other, basically meaning static camber would remain unchanged, you could do anything you wanted to the middle curvature. Loop that guy out wide allowing to clear wider tires.
    If i get bored this weekend, i could model something up in solidworks and show you guys
    Veteran Member Four Rings Kyle H's Avatar
    Sep 21 2006
    98 A4 1.8tQM
    San Diego, CA
    Are the rear uprights different on the S4 or A6? If so, maybe they allow for more clearance and will bolt up?
    Great thread, I thought I'd be doomed to 225/45-17 with my car... it's good to know there is hope!
    "Einstein: Any man who can drive safely while kissing a pretty girl
    is simply not giving the kiss the attention it deserves. "
    because racecar.
    Feb 15 2008
    E46 323i 5-Sp
    616/MI
    Quote Originally Posted by Kyle H View Post
    IIRC S4's are identical, and A6's have a completely different rear end setup.
    I have been curious about making a different rear spindle as well. It seems to hinder a lot of people, but I don't think anybody would be able to meet the pricepoint of the avg consumer.
    Mar 09 2004
    nw michigan.
    Quote Originally Posted by big_greasy_taco View Post
    It isn't a difficult job. Fixture the hub and mating portions of the spindle. Cut out the offending section and weld in a new piece. You would need good welds and some basic engineering but there is no reason it can't be stronger than stock at close to the same weight.
    Or I could scan it into a point cloud, alter it in cad and run FEA, cnc a mold for lost cores from 40# foam, coat those wax cores in ceramic with sprues, melt the wax out and replace it with molten aluminum. Little machining and now we have stronger uprights with perfect clearance and they weigh half as much as the stockers. All I need is a $10k deposit to get this rolling.....
    Jim
    I Do Werk.
    Feb 15 2008
    E46 323i 5-Sp
    616/MI
    Quote Originally Posted by onemoremile View Post
    My car isn't even worth that much...
    I could see somebody making a pretty basic boxed in bend that would clearance a wide tire. I don't see anyone coming up w/ 10K to do the CNC & molded process.
    Apr 28 2008
    Houston, TX
    10k deposit?? geeze thats kinda steep. I could model those guys up, run solidworks FEA, and throw the G-code on the CNC mill. prolly mill some 6061 T6 aluminum, which we get donated for our formula car team I could make some fo free and then charge 10k! And people say Mechanical Engineering sucks psh
    Feb 15 2008
    E46 323i 5-Sp
    616/MI
    10k deposit?? geeze thats kinda steep. I could model those guys up, run solidworks FEA, and throw the G-code on the CNC mill. prolly mill some 6061 T6 aluminum, which we get donated for our formula car team I could make some fo free and then charge 10k! Thats a weekend job
    Need any help? I could do a job like that, or relearn the stuff I would need to.
    Veteran Member Four Rings the_pirate's Avatar
    Apr 08 2008
    Houston
    wow that allroad looks dope.
    lets see the wheels!
    History:
    2001 A4 1.8t manual swapped
    2007 GMC Sierra ext cab
    2002 Chevy Tahoe Z71
    Senior Member Three Rings urban96's Avatar
    Aug 09 2007
    Syracuse, NY
    check these guys out...
    http://www.dpt-fast.com/
    -06 A4 2.0T
    -97 A4 1.8T
    Oct 27 2007
    In the lab
    Quote Originally Posted by the_pirate View Post
    Search for threads under my username
    This thread is going great and I don't want to derail it and turn it into a picture thread
    Apr 28 2008
    Houston, TX
    Just out of curiosity, a while back, i had seen a b5 3d model floating around, does anyone know of one? Doesn't really matter what format its in. If that model had the upright in it, that would make things ALOT easier to change and play with. Could even shove some fatty tires in and check fitment once i change it.!
