it was over a grand at the dealer for a brand new S4 one.
It's extremely easy. Two plugs, Just remove and switch to your new one.
10 minutes. Ok, 15 if you're drunk, missing two legs, and have trouble and bent over once too far.
The question inevitably becomes whether you can justify spending that amount of money for a Turn by Turn visual pop-up guidance system in your tach display. When in fact, the navigation itself is more than sufficient for your display needs.
GL
I failed to mention. You need to have it installed at the dealership because the immobilizer needs to be programmed into the new display. This can only be done at the dealership. nowhere else.
You're going to ask, I know. So I'm saving you the trouble now. It can't be programmed with vag, help from your alien friend name Cowbell, or your Mcgyver sidekick you carry in your trunk who knows how todematerialize matter using only a rubber band and a piece of hair from his eyebrow. The Answer is NO.
Originally Posted by
onceover
how much would one cost? How hard is an install?
