Results 1 to 2 of 2
    Registered Member Two Rings b6-sr20det's Avatar
    Dec 27 2007
    Bad radiator? Need 2nd opinion please!
    so i have been having some steaming from my A4's grill as of lately and a slight loss of coolant over time. About 2 days ago i had a low coolant light come up so i filled up the coolant resevoir. All of the sudden since i have filled the resevoir i started having a real big leak in the front of the car with it running. So i got a flashlight and i looked under the car to locate the leak but i was unable to find the exact location of the leak but i notice the coolant pooring off the front motor mount in the middle of the radiator. Im assuming its the radiator because there is no other coolant lines near it and the rad hoses are fine!
    So my question is does this sound like a bad radiator? and what is involved with taking it out to replace it?
    thanks -mike-
    Dec 28 2006
    '13 A5, '24 Tiguan SEL R-Line
    Western Maryland
    Re: Bad radiator? Need 2nd opinion please!
    Clicky click
    You can use the first section of this DIY to replace your radiator: Clicky click
    Good luck!
