Results 1 to 16 of 16
    Veteran Member Four Rings JumboBlack1.8's Avatar
    Sep 16 2006
    '98 528i
    Boston/West Hartford, CT
    Forge 001: Still gettin Comp Surge
    Quick question:
    So last week, I relocated my BOV to the cold side of my IC, only a few inches from the TB. But I'm still getting some compressor surge, which obviously really worried me. I'm currently running a Forge 001 single piston Blow Off Valve. Will these accept the same range of springs that the 007 DV's will? I think I might need to try a softer spring, since I'm running less than 15psi. If not, will I have to upgrade?.....i really want this issue to finally go away
    2000 Audi B5 S6 ** 4.2L 40v S6 6spd - http://www.audizine.com/forum/showth...n-s6-4-2L-swap
    Sep 16 2006
    '98 528i
    Re: Forge 001: Still gettin Comp Surge
    anyone?
    Oct 27 2007
    2001 Golf 2004 A4 USP
    In the lab
    Hmmm, are you sure it's compressor surge?
    Checked your boost gauge during throttle lift?
    Sep 16 2006
    '98 528i
    What else could it be? And what should I look for in the boost gauge?
    It sounds exactly like comp surge.....fluttering noise travelling through the system at throttle lift
    Oct 27 2007
    In the lab
    Hmmm... Ill be driving up thru Boston tommorrow... You wanna do a quick meet / diagnosis sesh?
    Sep 16 2006
    '98 528i
    Sure, I'm gonna be doin a coolant flush and replacing the CTS earlier in the day, but I can meet up in the afternoon....what part of boston you gonna be at?
    Oct 27 2007
    In the lab
    Call me homes, make it quick because I'm tirrreeeddd
    Veteran Member Four Rings Jibberific's Avatar
    May 21 2008
    az
    i think it's probably just some flutter from the diverter valve staying closed at boost levels that low. i'd bet the softer spring would let it open fully instead of forcing the air back through the compressor.
    {99.5 Avant}
    Oct 27 2007
    In the lab
    It is 18psi though...
    Sep 16 2006
    '98 528i
    Damn son.....my phone is outside....i'll call u in the morning (at a reasonable hour)
    Oct 27 2007
    In the lab
    OH, dude, why you not running 18psi?
    I didn't hear any at 18...
    Sep 16 2006
    '98 528i
    Quote Originally Posted by 317ssayzarc View Post
    I turned it down to about 15 after I got some predonation that I told you about.....It has been fine since tho...maybe I'll turn it back up
    Sep 16 2006
    '98 528i
    Well, we had the windows up the entire time.....it was cold as SHIT that day, and tomorrow is really gonna suck
    Oct 27 2007
    In the lab
    Hmmm...
    And just fyi, not trying to be a dick but just telling you, it's either preignition or detonation... Predetonation is, um, like nuclear shit or something lol
    Sep 16 2006
    '98 528i
    Hmmm...
    Lol.....damn.....2+ years on this site and i'm STILL a newb
    Oct 27 2007
    In the lab
    It's much more common than you think to mix the two
