Results 1 to 24 of 24
    Veteran Member Four Rings S4evr's Avatar
    Mar 07 2007
    Belmont, MA
    Timing Belt jumped a tooth?
    If you have been reading my other thread about cylinder misfires in the tech-section this is sort of a continuation of it, but with new details.
    My car was misfiring a bunch when it got warmed up, so i took it to a local shop. they replaced the coolant temp sensor and cylinder #4 coil pack. it idled just fine after that, and when it was hooked up to vagcom there were zero misfires across the board at idle.
    i went out and did 2 short wot pulls. as soon as i hit 5-10 it starts misfiring a bit, and when i get up to 20psi it starts backfiring like no tomorrow, i probably torched the bumper of the car behind me lol. bunch of dark smoke out the back too. no cel popped up, so i did it again. same thing; real loud and fast backfires as soon as i reach full boost except this time i got a flashing cel. i let off and drove normally, and maybe 10-15 seconds later the cel went away completely
    as of now no cel, and car still idles and drives perfect up to about 5psi.
    is it possible my timing belt jumped a tooth?
    ThorTechnik.com
    Nov 17 2006
    b5S4, b8.5 Allroad
    Las Vegas
    Re: Timing Belt jumped a tooth?
    Quote Originally Posted by S4evr View Post
    LOL im gonna have to say hell no
    if your belt was off a tooth you'd more than likely not be idling at all.
    interference motors dont do well with timing not TDC. bent valves would be your issue.
    continuous backfire and misfiring sounds like youre running rich as hell.
    Veteran Member Four Rings s2the4's Avatar
    Nov 02 2006
    01 Stage 3 S4 Silvaro, 01 S4 Avant Nogaro
    Western Mass
    Emil CHECK YOUR SPARK PLUGS!!!!
    |MRC-Tuned Stage 3| | RS4 K04 Turbos | | RS4 Y-Pipe | | RS4 Airbox | | RS4 Fuel Pump | | 60lb Siemens injectors | | ER SMIC | | APR Bi-Pipe | | All JHM Goodies | Vogtland GT | | Porsche 993 TT Brakes | | 034 Motor & Trans Mounts|
    ...For now
    417whp @ KTR Ayer, MA 110 octane with open dumps
    clicky
    Nov 17 2006
    b5S4, b8.5 Allroad
    Las Vegas
    Quote Originally Posted by s2the4 View Post
    most definitely. probably either way bad or improperly gapped
    Oct 31 2005
    Ashburn
    I posted some info in your previous thread, in the next coming weeks when i have time i'll be getting new spark plugs, and changing out my MAF and a coilpack. So hopefully that'll get her done.
    - Instagram: @Sinister_rs5-
    Mar 07 2007
    Belmont, MA
    yea i had thought the timing belt idea was way off, but worth a shot. i heard of it happen to others with similar issues.
    i changed my spark plugs 500 miles ago. i installed ngk bkr7e's all gapped to .028-- i doubled checked each plug before i installed them. However, i called AWE today and told them my problems. They said i need to be using the plugs they gave me with the kit (oem plugs). i looked up the specs of the ngk 6458's (oem) and the bkr7e's and the two are way different. i really hope thats the problem. i picked up some oem plugs at the dealer just now and i will be putting them in tomorrow. hope for the best!
    ThorTechnik.com
    Oct 29 2005
    10speed
    San Francisco, CA
    Quote Originally Posted by ThirdStrike View Post
    WRONG, you can give or take 1 tooth but you would throw a code for the cam not being timed right
    - Clint
    Nov 17 2006
    b5S4, b8.5 Allroad
    Las Vegas
    well if you want to put it like that.. yah.. but the risk of valves touching will still be there.
    my buddy somehow jumped 3 teeth on his 2.8 passat and didnt have valves hit.. doesnt mean you can go and mis align your belt 3 teeth off.
    Jan 29 2007
    08 S4 00 S4
    MD
    I'd second or third, whatever it is now, changing spark plugs. When mine start getting bad I get the same issues. Change them out and report back.
    08 S4- Stock SOLD
    Veteran Member Three Rings GetAwayFromMe's Avatar
    Jan 03 2008
    One million dollars all in pennies
    Iowa
    When i first picked my car up from the previous owner the car had a same problem as yours. PO told me he just had the plugs done 3 weeks ago. I took one out and yes they were new but bosh platnum the worst plugs ever. I had some plugs laying around from my old car 2.8 Passat, put those in went for a ride and not a single misfire.
    Car would misfire as soon as it hits 5psi.
    Aug 06 2008
    Canadia
    is our engine interferance?
    someone said to do the timing belt, by the book, you lock the cams, loosen the cam gears and crank the engine over by hand to get proper tension on the belt, if this is true, the pistons would kiss the valves during tightening.
    can anyone chime in if that is the way the timing belt is suppose to be tightened, or is that someones idea?
    the B5 S4 is like the mafia... there is only one way out!
    Senior Member Two Rings J-tec's Avatar
    Jun 27 2008
    2001 Jetta 1.8t - 50 Trim .63
    Boston
    Welp! We'll change em 2maro buddy, hell we could do it before i got class at 2
    Jan 03 2008
    Iowa
    Quote Originally Posted by MacDaddy View Post
    WHAT!!!!! You are j/k right?
    Nov 02 2006
    Western Mass
    Emil I ran one tank of VP unleaded 109 down at H20 and by the time I got home less than 1000 miles after putting in my BKR7E's they were toast! I am sure it is your plugs. report back tomorrow!
    ...For now
    clicky
    Mar 07 2007
    Belmont, MA
    changed out the plugs to the oem ones AWE says i need to use, and im still getting the same problems. i did a WOT run and got a flashing CEL again, except this time it stayed on. ill be pulling the codes real soon to see what is goin on now.
    so: its not the plugs
    ThorTechnik.com
    Jan 29 2007
    08 S4 00 S4
    MD
    So do you not have a VAG-COM?
    08 S4- Stock SOLD
    Mar 07 2007
    Belmont, MA
    my computer that has vagcom has a messed up screen, so i gotta wait for friend that has it to come by
    ThorTechnik.com
    Veteran Member Four Rings AMC's Avatar
    Jun 15 2007
    '19 Spektrum Golf RS, '18 Audi TTRS
    go and swap ecu's with somebody and see what happens
    Driver Supply
    Current
    '19 Spektrum Golf RS DAZA
    '18 Audi TTRS
    Sold
    '07 Stage 3 2.7t swapped B7 A4
    '01.5 Stage 63463 Silver S4
    '13 black Audi S7
    '03 Porsche 911T
    Veteran Member Four Rings SLC_S4's Avatar
    Jul 15 2007
    2001.5 S4
    Utah
    This might be a stupid question....but did you clear the codes after you changed the spark plugs?
    -Seth
    APR Stage 3 - APR Stealth exhaust - APR downpipes - APR Bipipe - APR snub mount - AWE side mount intercoolers - AWE LWFW - RS4 clutch - ITG panel filter - JHM Shifter - Startup Racing Vogtland GT coilovers - Stern adjustable control arms - Fiber Images vented carbon fiber hood - Fiber Images carbon fiber fenders - Recaro Style Topline seats - A bunch of other stuff I can't remember
    Oct 31 2005
    Ashburn
    He shouldn't have to clear the codes, although clearing them does erase any fuel trim data and upon start up it'll prob run fine but if that wasn't the issue it will come back.
    I've followed S4ever threads on this for awhile and he's changed plugs before. I bet the problem is going to be a coilpack or MAF, other wise it's o2 and EGT related.
    And if you have a mulitmeter you can test the voltages for all the connetors for everything from o2 to coils and egt etc.... Let me know if you need the info and values i'll try to get the info off my Bentley to you.
    Account Terminated Four Rings
    Sep 27 2007
    hate on me <3
    under the knife in, CT
    dont post if you dont know what youre talking about. the spread is stupidity is rampant.
    Sep 27 2007
    hate on me <3
    check plug gap first....is your car low on fuel also? its somethign simple...dont overthink it.
    Mar 07 2007
    Belmont, MA
    AWE told me to buy the plugs, and put them in. that is what all their technicians do, the gap doesnt need to be adjusted on the plugs i just put in.
    just pulled the codes:
    random multiple misfire detected
    cylinder 4 misfire detected
    cylinder 5 misfire detected
    ThorTechnik.com
    Mar 07 2007
    Belmont, MA
    if i could get those values from you that would be so great, let me know
    ThorTechnik.com
