Results 1 to 26 of 26
    Feb 19 2007
    2001 BMW 540i M-sport
    Charleston, SC
    Can cruise control remain constant with a MBC?
    Ever since I installed my MBC, it seems as though cruise control cannot maintain speed going up a hill. After searching the little threads that came up....its seems as though this is what to expect with a MBC, correct?
    Its not just cruise control though....As a driver I cannot regulate boost what-so-ever. Its either no boost or all boost. Obviously I am bypassing the N75 completely with the MBC (N75 is still plugged in though). Its not just going up a hill though, I cannot, for example, 30% throttle. Its getting real frustrating!
    i know others have MBC's...does your car have this probelm? Or do you just live with it?
    -Sami-
    Veteran Member Four Rings Audi Skate Snow's Avatar
    Mar 31 2004
    C300 Sport and tools
    CA
    Re: Can cruise control remain constant with a MBC?
    when I had my MBC before EBC, this was never an issue for me.
    BetaAlphaTau member #1.5
    R.I.P B6 A4!!!!!! 12/03/2005 12.63@108... stock 1.8 motor W/ GTRS.
    B6 A4 Avant, 2.0 Liter, 3071, Maestro
    Feb 19 2007
    Charleston, SC
    Quote Originally Posted by Audi Skate Snow View Post
    Did you run the MBC in-line with the N75 or just by itself?
    Also (like i said I am running just MBC the N75 is by itself but still plugged in).....do I need to close the other two ports on the N75? Or can they just vent to the atmosphere?
    -Sami-
    Veteran Member Four Rings widgget's Avatar
    Dec 18 2007
    nj
    ordered my MBC today so i can't comment on how well it functions with cruse control. you should leave the N75 connected to the TIP and then loop a small section of hose to the other two ports. if you don't do this your going to be sucking in unfiltered air, not allot but it doesn't take much sand to ruin your day.
    Feb 19 2007
    Charleston, SC
    Quote Originally Posted by widgget View Post
    thanks, i guess i will have to do that....but obviously that wont fix the problem, lol.
    its clear that the n75 controls boost...but why would I have this problem when others dont?
    -Sami-
    Jul 07 2004
    630AWHP A4, Nissan Titan
    socal
    Less of an issue with the larger turbos, more of an issue with a K03/K04 since the turbo spools up so quickly and this causes surging issues. This even becomes an issue with a mbc and K03/K04 while trying to hold part throttle going up a hill, the wg just becomes an on/off switch. Basically K03/K04 + MBC is a NO go.
    Forum Moderator Four Rings actlsub9's Avatar
    Jun 13 2005
    Audi
    There is no part throttle boost with an MBC. The wastegate will not be opened until you reach your set boost.
    N75 FTW
    Greg - Moderator
    WWW.ACTLSUB9.COM
    Mar 31 2004
    CA
    you should leave the N75 connected to the TIP and then loop a small section of hose to the other two ports. .
    this is how I ran my MBC as well.
    Veteran Member Four Rings sean1.8t's Avatar
    Sep 17 2006
    I wish I had a garage.
    SLC, UT
    Quote Originally Posted by actlsub9 View Post
    N75 FTW
    BT with no n75 and MBC.
    no problem with part throttle, you just have to be light on your lead foot. also no problem with my cruise.
    Current:
    '16 Mercedes-Benz C450 "AMG": Stage 2 w/downpipes & 19" BBS CH-R's
    '88 Harley-Davidson Sporty 880: 1200 bottom - Ported & Cam'd top - S&S In - Screamin' Eagle Out
    Previous:
    '02 Audi A4 1.8TQM: Full GT28RS on meth w/everything else.
    '01.5 Audi A4 1.8TQMS: Tune and exhaust.
    '99 Subaru Legacy Outback wagon Manual: Bone stock.
    I don't even want to remember the others
    Jul 07 2004
    socal
    Quote Originally Posted by sean1.8t View Post
    Yes because it is not a problem with a BT, its only a problem with a K03/K04 because you basically breath on the K03/k04 and it hits full boost.
    Sep 17 2006
    SLC, UT
    yes i know.
    i was just confirming your point and showing greg that there is partial boost with standalone MBC setups
    Current:
    Previous:
    Jul 07 2004
    socal
    Ok. I think the only thing that works well with the n75 is the K03/K04, after that point a EBC is the best choice.
    Jun 13 2005
    Audi
    yes i know.
    Different strokes for different folks.
    Unless I intend to boost over MAP limit, then its n75 for me.
    Greg - Moderator
    WWW.ACTLSUB9.COM
    Jul 07 2004
    socal
    You would be suprised at how much better the power band feels with a EBC vs a N75, even when running under 21psi.
    Feb 19 2007
    Charleston, SC
    Mike, that's what I figured... Guess I am SOL until I go bigger, eh?
    Is it possible for me to run the MBC online or in conjuction with the N75?
    Thanks guys
    -Sami-
    Dec 28 2006
    '13 A5, '24 Tiguan SEL R-Line
    Western Maryland
    Thanks guys
    Clicky click
    Feb 19 2007
    Charleston, SC
    Oldguy, thanks...... Again, LOL
    That was the exact thread I was looking for!
    One last question: after running the MBC in parallel will I have to reconfigure it? Or will it retain the current boost pressure I am seeing now?
    -Sami-
    Dec 28 2006
    Western Maryland
    The N75 will control the boost. The MBC will clip any spikes if it is set below the N75 threshold. If the MBC is set above the N75 then the N75 will control the maximum boost.
    Feb 19 2007
    Charleston, SC
    Just to clarify, I have the MBC set to 16psi....so the N75 will limit me to stock settings (~10psi)?
    -Sami-
    Dec 28 2006
    Western Maryland
    If you are running stock tuning with the N75 you will be limited to around 11 psi. Having the MBC set at 16 but run in parallel with the N75 will not raise the boost any. The N75 is going to clip it at 11psi. Now if you were running some other tune that was causing a nasty spike that you wanted to control, running the MBC in parallel would be a way to control it by capping the maximum boost. For example, running a K04 with the 1+ (FXK03) file will cause a wicked spike. You could control this running the N75 and capping the boost with the MBC. (Not that i am recommending this set up!)
    Feb 19 2007
    Charleston, SC
    I see, I see
    See I am on the stock software. I did the "diode mod" about a week or two ago. I guess I am SOL until I go bigger and actually get a file.
    Thing is there are plently of VW's and B5's doing this diode mod. Car runs great and finally has some balls, lol. Its just partial throttle that kills the car/ride/drive.
    -Sami-
    Sep 17 2006
    SLC, UT
    plus i like the added benefit of controlling boost to exactly where i want it.
    no spikes, and no suprises.
    the n75 was intended for stock cars
    Current:
    Previous:
    Dec 28 2006
    Western Maryland
    I didn't realize that you were running the "diode" mode so I'm not really sure what would happen if you ran the MBC and N75 in parallel. If I understand the diode mode correctly you are "fooling" what the ECU sees from the MAP sensor and consequently raising the boost. Having no experience with the diode mode I don't know how far you can "fool" the ECU into raising the boost. I would think running the N75 would help reduce the on-off effect you get from just running the MBC and you could still use the MBC to cap the maximum boost so you don't fry your motor when you start to lean out from insufficient fueling.
    Feb 19 2007
    Charleston, SC
    Thanks oldguy, I will give it a try tomorrow.
    Lets hope the motor doesnt run lean now, lol...I've been logging and everything seems to be doing alright
    I see it as the diode mod is the same as Stage 1 (stock injectors)
    -Sami-
    Apr 01 2007
    1983 Chevy Silverado
    houston texas
    ive got the diode mod and its the same. its gotten a little better since ive fine tuned the mbc's spike and course boost.
    barrett
    2019 SQ5 Prestige
    Veteran Member Four Rings audikid66's Avatar
    Jun 13 2007
    Belmar,NJ
    will it be better to run an EBC with my k04 rather then a MBC? i had the mbc on when i had my k03 and i loved how the boost came on
    Current car: Stage 3+ 2002 Audi allroad 6 speed
    Past cars:
    imola b6 avant 5spd/URS4 avant Big turbo aan/B7 RS4/k04 b5 Avant /BAT B5 Rally car/B6 Ultrasport/TT / multiple B5 A4 /5 speed ford f-150
