Results 1 to 19 of 19
    Established Member Two Rings Asimko's Avatar
    Apr 26 2008
    Another brake newb...but I searched
    Sorry to bother everyone but I have a few questions. I have an 06 A4 S-Line which I purchased 6 months ago. I called the stealership today when I got the brake light on the dash and they gave me an outrageous price to do the brakes. My questions are:
    1. Does it seem too soon to be replacing the pads when the dealership said they were checked before they sold it to me? I have put 10K miles on it since I purchased 6 months ago and the dealership said that it was normal for new pads to be replaced in 10K?? Funny my VWs went a lot longer.
    2. If I do it myself are there sensors on both front and rear brake pads? This will help me tell which ones I need to replace. Which usually goes first front or rear?
    3. Should I go with Hawk Ceramic or HPS? I want less dust with a good life and hopefully no squealing.
    4. I have a little lip on rotor, can I get away with not changing them?
    Thanks in advance
    Veteran Member Four Rings eMacPaul's Avatar
    Jul 25 2008
    Marysville, WA
    Re: Another brake newb...but I searched
    10K does seem pretty short, unless you ride the brake.
    But maybe by "check" they just meant they checked to make sure it wasn't worn all the way down yet when you bought it.
    2007 A4 2.0T CVT Cabriolet S-Line Phantom Black
    APR, K&N air filter, Podi boost gauge, chrome-stripped grille, RS4 RSB
    Smoked side reflectors & markers, smartTOP, Eibach Pro-Kit, 12F/15R spacers, ER SMIC
    Xenon match DRLs, LED fogs, city w/ fogs, S4 mirrors, red LED interior, CC, 034 HFC + Magnaflow 14829
    Apr 26 2008
    Her words were "I have seen new pads go in 10K and 40k it just depends".
    Veteran Member Four Rings Slo.Mo.Shun.'s Avatar
    Oct 14 2006
    MK6 Jetta
    South,FL
    Do them some where else, I changed my pads at 30K, and I am the type of person that gets rotors out of shape and heat spotted.
    -Unitronics Stage 2+ ECU/TCU tune.
    -EI AL CAI.
    -Driver Mod.
    Veteran Member Four Rings vtracer20's Avatar
    Apr 14 2008
    Milton VT
    that does sounds short for brakes...but also depends on your driving habbit. Go with HPS...i dont think you need ceramic unless you go tracking.
    2007 A4 S-Line / Ti Pkg / Quattro / Bilstein Pss9 / JHM Short shifter / GIAC X+ chip / RS4 rear sway bar / 20% rear tint / 10mm front 15mm rear spacers / Forge DV / DTM CF replica rear lip spoiler / DTH CF roof spoiler / Cupra R front spoiler (not on) / Infinity BasslinkII sub
    looking for: CF front lip / S4 alum mirror hosing
    Veteran Member Four Rings supamannn99's Avatar
    Nov 15 2007
    Orange County, SoCal
    i replaced my stock ones with hawk ceramics for improved brake performance and reduced brake dust.
    if you care about the life of your rotors, dont get HPS because they eat up your rotors as a trade-off for max braking performance. they sometimes squeal as well.
    I like my ceramics.. they are quiet, grab better than stock pads, and have less dust.
    if you do it yourself, there ARE sensors in the front. make sure you get the ones with sensors or else you'll get codes thrown at you.
    changing stock pads every 10k is bs. your stealership is lying
    Established Member Two Rings Bart-Man's Avatar
    Aug 19 2008
    06 audi a4 2.0T
    Does every B7 have sensors on the front.
    Because I think my breaks are going but nothing is indicating on the display.
    Veteran Member Four Rings p1nk50ck's Avatar
    Sep 18 2008
    06 Audi A4 S-Line
    Arlington, VA
    Quote Originally Posted by Bart-Man View Post
    why do you think your brakes are going? did you inspect the pads? did you check your rotors?
    just because they squeak doesn't mean that they're bad.
    Veteran Member Three Rings Latin Audi's Avatar
    Mar 18 2008
    '63 & '75 Nova
    Texas
    ^ When I changed mine, the sensor was was located approx. half an inch before the pads are spent, so you could keep going on them but the brake light beep could get annoying.
    Quote Originally Posted by Asimko View Post
    Thanks in advance
    1. yes, this seems a bit early
    2. I believe there are sensors on both, but Ive only changed the front on mine.
    3. I went with some cheapos from local store
    4. If you have a lip, go to autozone like place and they will first measure if they can be turned and if they can they are only ~ $15 each rotor to turn them.
    Brilliant Red 2005.5 A4 2.0T Quattro 6MT
    APR 93 | Evoms CAI | RS4 Sway | CC | De-Badge | ECS Snub Mount | 5%| Ziza City Lights
    Veteran Member Four Rings elwigglero's Avatar
    Sep 04 2008
    B7 S4 DTM, B7 A4 2.0T Ti
    Lansdale, PA
    They're easy to replace. It's a pad with a wire that connects to a plug. If your rotors have a large lip on them, it's prob time to either have them machined (eh) or get some performance rotors that are either drilled/slotted/dimpled (uh huh).
    New rotors and a good set of ceramic pads are a nice upgrade.
    Active Member Two Rings mdfast1's Avatar
    Feb 27 2008
    Sunnyvale, CA
    My 2006 has sensors. It took until it got really worn down to go off and bother me every minute. Replaced mine (rotors/pads) at 45k miles. Got the GSG (ghost squad garage) rotors, we will see how they work out.
    2006 A4 Quattro 2.0 T (RED T)
    Mods: RS4 Anti-sway bar, LED Interior Lights (red), GSG Slotted/X-Drilled Rotors
    Apr 26 2008
    Is there a dominate set of brakes? I know on my last VW the rears would go quicker. I have a quatro if it matters.
    Apr 26 2008
    Ok dealership is being a pain and giving me the run around so im doing the brakes myself. Can someone please tell me the tools I need so I make sure to get the right stuff. I know I need the special brake caliper tool, but what else?
    Senior Member Two Rings D-techniK's Avatar
    Feb 24 2008
    Miami Lakes, FL
    my brakes went at 36k.
    Apr 26 2008
    Im only at 32 so they have to be the original brakes but any idea on what tools are needed???
    Veteran Member Three Rings Kschroers1's Avatar
    Jan 12 2008
    17' Jeep Grand Cherokee Limited 1942 Edition, 12' A4 Premium S-Line 6spd Quattro
    Roanoke, VA
    A lift, 17 mm socket to take off wheels, and i can't remember the size, but its like a 35mm torx socket for the caliper and i think somewhere between 19mm-22mm socket for the caliper brackets. Note: Never turn your rotors. An audi specialist at my dealership said to not turn them, it makes them weaker and won't keep to performance. Just scuff up the rotor's with sandpaper to make the bite aggressive quicker when you first put on the pads. I had an ordeal not long ago where my pads were squeeling constantly and im just under 10k miles on my car. I scuffed the rotors, and shaved the side of the pads to allow air to pass through and help with the brake dust. Since i've done that, i have yet to have a break squeek when im stopping.
    2012 Audi A4 Quattro 2.0T 6spd Premium / S-Line / Ibis White/Tan Interior
    2017 Jeep Grand Cherokee Limited Willy's Edition / White
    Apr 26 2008
    Thank you, as long as thats all that is needed I will have all the tools. I will also be replacing my rotors with the ECS drilled and slotted. Any one have any other recomendations for rotors?
    Feb 27 2008
    Sunnyvale, CA
    Adams Rotors or GSG (ghost squad Garage). I just ordered a front set of GSG rotors so we will see how they work. I heard good things about both rotors though.
    Check the group buy section.
    Veteran Member Three Rings barkerd427's Avatar
    Oct 04 2006
    2007 Audi A4 & a honda
    Princeton, NC
    I am at about 52k and my brakes are still looking quite good, but I think I will replace them anyway during christmas because I am tired of washing the car and having brake dust all over the front rims before the day is out. I don't even think I have to drive it to get them covered again. It is a pretty easy job, but the rears are harder because you need the caliper retractor tool. Your fronts should always wear out about twice as fast which is obvious if you think about it for a second. To clarify for those that are a bit dense. When you stop the weight goes forward and is primarily focused on the front tires. The back will actually lift a little if you stop hard and the front will dip. If your rear brakes are wearing out quicker then you probably have a sticky parking break or a stuck caliper that is holding the pads against the rotor at all times gradually wearing them down the entire time you are driving. Our cars have self-adjusting calipers so when you change your brakes you need to pump the brakes 5 to 10 times so they will set properly.
    2007 A4 2.0T S-Line Quattro / Deep Sea Blue / Black Leather Interior / Nav / Heated front seats / Xenon head lamps / APR Snub Mount / RS4 Pedal Set / RS4 brushed aluminum grille / RS4 rear sway bar / RS4 parking brake handle / Xenon match interior lighting / SOON Custom fog light grilles with S6 LEDs and RS4 mesh and brushed aluminum trim, just need to find the trim
