Results 1 to 15 of 15
Thread: Turbo LB/Min
    Veteran Member Four Rings Evilevo's Avatar
    May 26 2008
    2018 TTRS, 2014 Q5 TDI, 2020 Supra, 2022 F150, 2004 V70R
    MD
    Turbo LB/Min
    Does anyone know the LB/Min ratings of K03s, K04s, and RS6s?
    I searched and googled, but couldnt find anything
    Jun 14 2007
    2000 S4
    Connecticut
    Re: Turbo LB/Min
    ive been asking about K04 rates but never got a solid answer... id be interested as well
    Account Terminated Four Rings
    Mar 14 2007
    michigan
    Re: Turbo LB/Min
    k03 like 16-17lbs k04 22lbs rs6 25-27lbs
    all these comp side numbers mean very little on a turbine side that is small.. You can let in all the air you wish if it cant get out then it will actually hurt more then help.
    May 26 2008
    MD
    Re: Turbo LB/Min
    Quote Originally Posted by generationjdm View Post
    Right, im just wondering how big my Innovative RS6s are compared to stock and K04s
    Mar 14 2007
    michigan
    Re: Turbo LB/Min
    Quote Originally Posted by Evilevo View Post
    About 30% larger.
    The rs6 turbine wheel is virtually the same size as the pjk04 turbine wheel with in .5 which is nothing. So going really big on the comp side if your trying to compare and I dont no if you are or not is a little different in comparing lets say a gt2554 with a 27lb comp wheel and the modded rs6 let say with a 30lb comp wheel, the 25 will still make more power cause of the much larger turbine side.
    May 26 2008
    MD
    Re: Turbo LB/Min
    Ya, that is the thing, I am not exactly sure what is done to my turbos. They are the same as the TQ Factory car from USCC 2007, from what i have been told.
    Mar 14 2007
    michigan
    Re: Turbo LB/Min
    I think you will be getting just a larger comp wheel of 30-33lbs, thats really all that can be done
    May 26 2008
    MD
    Re: Turbo LB/Min
    i already have them. they are on the car already. I know they are ported and clipped with higher pressure WG Actuators. Not sure exactly how big the wheel is tho. I was told at one point 50lb/min, but i feel that is too big
    Mar 14 2007
    michigan
    Re: Turbo LB/Min
    could never be a 50lb a minute, i believe they where doing 30lb
    May 26 2008
    MD
    Re: Turbo LB/Min
    Thats what i thought. I thought that the turbo housing were too small for a wheel that big. Thanks!
    Maybe ill just email Innovative about em
    Aug 06 2008
    Canadia
    Re: Turbo LB/Min
    you talking about compressor surge?
    the B5 S4 is like the mafia... there is only one way out!
    Mar 14 2007
    michigan
    Re: Turbo LB/Min
    Quote Originally Posted by MacDaddy View Post
    Not really just that but think of it this way. Imagine running a marathon where you can inhale freely through your open mouth but you're forced to exhale through a soda straw, so tossing a larger comp wheel on a tiny/choked turbine side means nothing if the air can't get out. It will actually back up and create weight on the turbine wheel and under perform/spool. Picture having a wheel spin clockwise and putting heavy air pressure against it counter clockwise. The rs6 comes with a larger turbine housing then the pjk04 which is what really helps that turbo perform better then the pjk04..
    Aug 06 2008
    Canadia
    Re: Turbo LB/Min
    I see, so its not stalling the turbine, but there is alot of resistance on it.
    So whats the cure in your opinion? larger charge piping/bigger intercoolers?
    Mar 14 2007
    michigan
    Re: Turbo LB/Min
    Larger turbine side or not putting a real large comp wheel on a small hot side
    Oct 29 2005
    10speed
    San Francisco, CA
    Re: Turbo LB/Min
    you can stick an 80lb wheel on the coldside, but that hotside is holding you back, this is why in theory GT turbo setups should be so much better
    - Clint
