Problem - Car runs pig rich at WOT (9.3 AFR according to my innovate wideband).
I recently upgrades from Mika to the Unitronic 630cc-3bar file and i am still running rich at WOT, to the point where it starts to break up.
- No CEL's
-I have pressure tested for boost leaks. There are none
- Vacuum is good. 23 inHg @idle
- Tried disconnecting the W/M inj.
- Confirmed with Unitronic that the fueling setup should work (550cc@4bar)
-Tried different boost levels, all seem the same, holds boost fine.
I have no idea what is causing the car to run this rich.
Any input is appreciated, I have run out of ideas.
