Originally Posted by
Sizzle
50k is a good deal, especially for dealer versus private seller pricing.
To get around your stereo issue, you just have to keep the main dash headunit. You can then add your amps and whatever compeonent speakers set you choose and power them up.
I briefly considered upgrading the stereo, but decided against it. I was gonna go full Dynaudio powered with Mcintosh amplifiers....
What are you considering doing??
Haha, I had McIntosh MX406+MCC404+MCC302 in my Mercedes with DLS components and MBQ subs. My verdict on the relatively inexpensive $850 B&O system is that I'm ABSOLUTELY AMAZED. It sounds comparable enough that I wouldn't bother with aftermarket audio in the S5 unless I planned on waking up the neighbors. It doesn't have the overall output of a multi-kilowatt system, but it definitely has
plenty.
Once setup, the B&O imaging is damn near perfect; the front 3-ways are positioned great for imaging for both front passengers (although the DSP allows you to focus on just the driver, if you like). Only complaint from an overly scrutinizing point of view is that it can get a little bright at higher volume, and I really wish there were a parametric EQ, or at least a graphic one with more than 2 bands.
If it were easy to do so, I'd supplement with a beefier amp and add a 30-band EQ to have more control over the midrange, but it's hard to find the desire to mess with a perfectly integrated, perfectly clean installed stock system, so at this point I'm perfectly content with leaving it alone.
