Originally Posted by
wildcharlie
I was interested in the Laser* sponsorship program that ran through October but with all of the board reading I've been doing
L*
What about a Blinder 45 vs LI 2 head? They would be about the same price.
Well that's not a fair test my friend. When you run a 4 head setup you are going to be able to block FAR more of the front of your car so you are doing a dis-service to the LI 2 head setup. On the other hand if you were planning to use the m45 (4 head) setup with two heads on the front and two on the rear then I would also say that it would get you better all around protection but the LI 2 head setup would block better in the front.
Anyway, if you were at all considering going with a 4 head setup, I would recommend that you get a 2 head setup and upgrade to a 3-4 head set up later so that you can save some cash on the front end. Just my 2 cents.
To me, if I were to choose between a 4 head setup from blinder (using all 4 heads in the front of the car) and an interceptor setup (2 heads in the front) I would go with the blinder 4 head setup because for a car (not a SUV or truck) it is normally overkill if you are taking other precautions like veil and removing bling bling things from the front of your car.
