So i upgraded to the 034 HF mani and my MBC was previously set to 15psi and now im seeing boost in excess of 20psi which is not where I want to be. Now I can simply turn the boost down but my question is would the extra flow provided by the 034 Mani create the increase in boost? My guess would be no because the MBC is mechanical in nature and the spring rate is fixed so the opening of the wastegate is a function of where the MBC is set (spring rate) and not the exhaust flow. Correct me if I'm wrong. Hope what i wrote made sense.
