i have been working with Shawn down at 1552 and directly with APR to figure out what is up with my car. we have replaced a lot of parts and not gotten any closer to a fix. all the mods are listed in my sig. here is what i have been dealing with. i am open to ideas!
this all started because i was getting terrible gas mileage - about 13 city and 19 highway - and i was having an intermittent boost problem. around town i boost fine - spike around 19-20 and hold at 16-17. once i get out on the highway and cruise for about 10 minutes, my boost drops by a full 10 psi. it will peak around 9 and hold at 7. i was not getting any CELs and I didn't have a VAG cable, so i don't know if there were any other codes.
i did a few things to try to fix the problem, including getting a VAG cable to help with the diagnosis. i did a triple sea-foam treatment, changed the oil, put in NGK BKR7E spark plugs gapped at .28 and replaced the DV - no improvement. i also did a pressure test on the system & found no vac or boost leaks. i checked the codes and got a P0171 - system too lean.
next, i replaced the MAF - no change. replaced the primary O2 sensor - no change. pulled a P0141 code (once, but never again) and then started pulling P1128 - system too lean. i get the P1128 code over & over now, and sometimes it throws a CEL. i also replaced my coolant flange and engine coolant temperature sensor and N75 valve. nothing has made any improvement. my mileage still sucks and i can't boost over 7psi once i drive on the highway for more than 10 minutes.
here are a few logs i ran today - all of these are 3rd gear pulls from 2k to 6500 rpm.
the first 2 were this afternoon when the car was boosting fine:
these next 2 are the same channels but from the evening when the car was not boosting well. i had a CEL on at the time.
channel 115 in the evening run tells the boost story. the car is requesting the right amount of boost, but it isn't making it. once i clear the codes, i'm back to full boost. WTF?!?!? i think that is about the entire story. can anyone help?! all i want is 18-19psi boost and 28mpg highway with no lean codes or CELs. any thoughts from anyone?! thanks!!
btw, here is a picture of the car...
