Results 1 to 12 of 12
    Registered Member Two Rings
    Nov 15 2008
    2005 S4 6spd, Suzuki B-KING
    Chicago Burbs
    H & R coil over ride quality
    any input guys? Thanks
    Don-
    Light Silver/Blk 2005 B6 S4 Six spd every option - Carbon Fiber - LM25's on stockers - Ruger R10 19's - Falken 452's 235-35-19's - Milltek Non Res CB-Magnaflow 14851's Mufflers- X-Pipe - APR DP's - Rs4 Pedals - JHM SSK - Flapper mod - WAITING on JHM LT's
    Veteran Member Four Rings ieatfishburitos's Avatar
    Jan 10 2007
    Earth
    Re: H & R coil over ride quality
    My car is slammed, I put them on the same time as the super stiff sway bars so can't really decouple between the two. It's definitely firmer and you can feel more of the little bumps. Again I can't say if thats because I'm slammed or what, but I love it! Car handles great..
    Haven't had other coilovers either... Based on my reading get the best ones you can afford. For the under 1500 price range these were my pick..
    2013 White 911 4S
    Gone but not forgotten:
    2015 Sepang Blue S3 - 1 of 5 exclusive edition
    2004 Nogaro Blue S4 Avant w/ Noggy interior
    2005 Moro Blue S4
    Account Terminated Four Rings
    Mar 09 2005
    Widebody S4 Noobs Destroyed: 9
    Santa Clara, CA
    mr burrito: have you had any tire wear issues with your super low ride height?
    Veteran Member Three Rings J.the W.'s Avatar
    Aug 30 2007
    2014 CP M5, 2006 Pathfinder LE
    Az.
    I love my H&R coilovers. No complaints.
    Jan 10 2007
    Earth
    Quote Originally Posted by ngng View Post
    Nope not yet... The car is just a little bit out of alignment. I wonder if the the previous owner had it lowered as the front tires that were on the car when I bought it wore out on the inside sidewall after 5k miles (I actually had a flat and it ripped all the way around while the rest of the tire looked great)...
    Thanks for bringing it up, I'll give it a thorough inspection.
    2013 White 911 4S
    2005 Moro Blue S4
    Mar 09 2005
    Santa Clara, CA
    Quote Originally Posted by ieatfishburitos View Post
    i'm tryin to figure out my ride height still
    Senior Member Three Rings Rodknock's Avatar
    Jun 25 2008
    The Dirty T, WA
    I have the H&R's on my car as well.. The rears are all the way down and the fronts have about an inch left to go.. The car is firmer than stock but its not bad. You will feel more bumps but its all worth it when you get out of the car and look back at it.
    Love my suspension. I am also slammed. As stated above i do feel alot more bumps, but the handling is great.
    Mar 12 2007
    Boston
    I had H&R coils on my B5. Nice value but I did NOT notice a marked improvement in handling. The ride was firmer but not jarring. I installed Vogtlands on my B6 and the improvement in ride quality was far more noticeable. The floating sensation of the stock suspension was gone and the ride was much tighter. Huge improvement. The fact that that Vogts are about $150 cheaper than the H&Rs doesn't hurt, either. Either one will put a smile on your face, though, because the car looks SO much better with a drop.
    SOLD 4/16/15- '08 Daytona Gray RS4/Black leather/CF trim/35% tint/MTM 10mm spacers/Euro steering wheel/GMG catback w/ Magnaflow DPs
    SOLD 9/4/11- '04 Nogaro Blue S4 w/ LaBree Resonated Fullback/ Vogtland Coils/ ECS Snub Mount/18x8.5" et32 Diamond Black RS-GTs
    Established Member Two Rings rbells4's Avatar
    Oct 27 2008
    2006 Audi S4, 2010 Ducati M696
    Los Angeles, CA
    I had H&R COs on my B5 and had the opposite experience as tadhgbrosnan: I noticed a huge difference in handling and ride quality. At times, the quality can be a bit harsh but not too much so; it's just sporty. The handling is insane. I'm selling it, since I have a B7 S4 and am going to buy new coilovers soon.
    My only complaint with H&R is that warranty repairs take forever, since they're located in Bellingham, WA and I sent mine in for a LOT of warranty repairs (4 in the past 6 years...which is unacceptable in my book). Planning on Stasis this time around.
    Ryan
    2006 S4 - Brilliant Black w/Silver Alcantara, nav, yadda yadda yadda, black calipers, clear corner, Vogtland GT.
    2010 Ducati M696 - Red, carbon termis, rizoma mirrors, etc.
    Nov 28 2007
    04 S4,Volvo P1800,03 Silverado
    Massachusetts
    i have them as well and love them
    04' Nogaro S4 - 19" BBS RS-GTs - H&R Coilovers - Hotchkis RS4 Sways - 4500k HID fogs - JHM solid shifter trio -JHM intake manifold - JHM port matched intake spacers - JHM longtube headers - JHM tune - Fast Intentions resonated catback - Snub mount - Vag mods - hardwired V1 - Clutchmaster Stage 3 clutch & 13.5 lb flywheel - Euro B7 RS4 steering wheel - Cayenne Big Reds - stern engine mounts - Stern upper control arms - K&N panel -
    Veteran Member Three Rings AndreNY's Avatar
    Apr 06 2005
    Boston MA
    def good coilovers a bit stiff but otherwise worth the money, another coilover i would recommend is FK, those are your best bang for the buck
