Results 1 to 40 of 45
    Veteran Member Four Rings FLACO X3's Avatar
    Jun 05 2008
    B5S4, B7A4
    Thornton & Elbert County, CO
    Very SLOW GTRS "build"
    going with the GTRS Eliminator with Eurodyne (Chris Tapp) tuning down the road, Im starting to get the parts and prices together early.
    So far the list is: (required)
    GTRS Eliminator Turbo
    Software
    Siemmens 630cc Injectors
    FMIC
    Test Pipe
    Apperantley the software doesnt require a AFPR or bigger MAF, but I may still get them in case. Im also looking at a exhaust manifold, intake (w/ 3" MAF), fuel pump & rail, GIAC TIP chip, ect.
    current mods:
    Eurodyne ECU
    Borla V1
    the car is a tip and daily driver (110 miles round trip daily), so it'll be a slow build.
    Input and advise welcome.
    2000 S4
    2008 A4 2.0TQ
    Account Terminated Four Rings
    Aug 16 2007
    Buffalo NY
    Re: Very SLOW GTRS "build"
    ig you are going eliminator stick with the stock manifold... less likely to crack and give you problems... and its free!
    Feb 27 2005
    North Wales, PA
    i have a stock one you cans port and polish a bit. make an offer
    Jun 05 2008
    B5S4, B7A4
    would a 2" FMIC core be enough?
    2000 S4
    2008 A4 2.0TQ
    Jun 04 2007
    01' A4 1.8TQM;15' Wrangler
    Austin/DFW, TX
    Quote Originally Posted by FLACO X3 View Post
    Id say 2.5" thick at least. I definitely want to hear how your tranny holds up with the injectors and that turbo. How many miles do you have on your car?
    BetaAlphaTau Member #12
    01' A4 1.8TQMS 5spd swapped
    My 5-Speed Swap DIY
    - B6 USP
    Jun 05 2008
    B5S4, B7A4
    I currently have 121,443 miles exactly. The transmission and MPG are the two things Im looking at closely. 630cc seems a bit agressive for stock pump and FPR, so I'll be buying those just in case.
    would any test pipe bolt up to the turbo?
    2000 S4
    2008 A4 2.0TQ
    Jun 04 2007
    Austin/DFW, TX
    Yes sir!
    Edit: a test pipe made for an a4 of course though.
    My 5-Speed Swap DIY
    - B6 USP
    Jun 05 2008
    B5S4, B7A4
    you have tranny problems with your set up?
    2000 S4
    2008 A4 2.0TQ
    Jun 05 2008
    B5S4, B7A4
    Apperently I'll be needing a MBC, how do I install it? I have the 034 motorsports one.
    2000 S4
    2008 A4 2.0TQ
    Mar 26 2005
    01 A4 1.8t avant; 04 B6 S4
    All over the Bay Area
    gotta watch this thread. i'm thinking of doing the samething in the near future, 113k on my car. tip as well
    TEAM|AXION
    Jun 04 2007
    Austin/DFW, TX
    I haven't had any problems with my setup yet but then again my turbo is a little different a puts out less power. I'll post up a picture on how to hook it up when I get home later.
    My 5-Speed Swap DIY
    - B6 USP
    Jun 05 2008
    B5S4, B7A4
    Quote Originally Posted by speedydragon View Post
    thanks for showing interest. it will be a slow build though. Im fixing my heater next week and then will do a test pipe and maybe rotors or sway bars. im just piecing things together and planning ahead to try to avoid problems. Also i dont to spend all the money at once.
    here is the MBC
    If i were to give a ball park on the date, id say next spring at the earliest or when the k03 blows.
    2000 S4
    2008 A4 2.0TQ
    Veteran Member Three Rings Naudi_Mat's Avatar
    Nov 02 2007
    2008 S-Line A4
    Denver
    Hey Flaco, I'm gonna be watching this thread as well. Since I'm in the process of building up and getting all the parts together for my new turbo install. And since we're both local if ya need any help with anything just let me know and I'd be glad to lend a hand.
    Jun 05 2008
    B5S4, B7A4
    what turbo are you looking at with your set up?
    btw your sig reminded me about the heater. just set up a date to fix it with Avalon. after that is done, the stock up of parts can begin.
    2000 S4
    2008 A4 2.0TQ
    Jun 05 2008
    B5S4, B7A4
    for the IC piping, what diameter is the GTRS inlet and would the charge pipe for a k03 FMIC set-up connect to the 'RS?
    2000 S4
    2008 A4 2.0TQ
    Nov 02 2007
    2008 S-Line A4
    Denver
    For right now KO4, but I'm looking at going GT28RS next year possibly. It all depends on money flow and if these job goes thru here in the next couple weeks.
    Nov 09 2007
    Alaska
    Cool build! i am doing a similar setup.
    I have a 97 A4 automatic and the turbo died and have the following which i have/was going to put on the 97
    GTRS
    Genesis 415cc @ 3bar
    Racetec Intercooler
    Techtonics Exhaust
    Forge007
    CAI + hoses
    And getting a test pipe
    But I'm going to do it right and find a 99.5 A4 1.8TQM and swap everything.
    I have been reading about the 3" MAF Housing and it makes sense, but Revo/Unitronics dont really have any specs on what is required for their software.
    Giac does not have software for the GTRS nor does APR (From what i understand). So i may have to get the Revo which i have read runs good. (Dont know much about the Chris Tapp Tune)
    The GT28RS might have been a better option since the turbo itself is cheaper, but a new exhaust manifold and test pipe would be needed. You may want to consider it It might come out to be around the same price with more power
    Mar 26 2005
    I plan on upgrading my dv, get a fmic, and replacing/upgrading all my mounts before going on to purchase the GTRS kit
    TEAM|AXION
    Jun 05 2008
    B5S4, B7A4
    Im trying to figure out prices on this. All our ball park, you can find them cheper if you look. So far from verious sources Ive found different prices.....
    GTRS Elim. turbo kit- $1,395-1,595
    Sofwre/tune- $700
    Siemens Deka 630cc Injectors- $220
    FMIC- $300-2000
    Test Pipe- $145-250
    GIAC Tip Chip- $300
    MBC- $65-120
    EBC- $120-??
    AFPR- $
    MAF- $
    Intake/TIP- $125-300
    someone know some of these prices???
    2000 S4
    2008 A4 2.0TQ
    981CGTS, Cayenne Turbo, '22 A4 Allroad
    Chicago 'burbs
    FMIC- $300-2000
    Test Pipe- $145-250
    GIAC Tip Chip- $300
    MBC- $65-120
    EBC- $120-??
    AFPR- $
    MAF- $
    Intake- $125-300
    Skip the tip chip go for a valve body. Much better IMO
    2014 A4Q Red w/ black optic black interior
    Jun 05 2008
    B5S4, B7A4
    im considering a level 10.
    found a cheap test pipe in the classifieds. PM'd the guy.
    2000 S4
    2008 A4 2.0TQ
    Jun 05 2008
    B5S4, B7A4
    just found some 60 lb. injectors on AW
    2000 S4
    2008 A4 2.0TQ
    Jun 04 2007
    Austin/DFW, TX
    I also have considered it, but I wonder if putting a BAT on an A4 would be really worth it having an A/T.
    My 5-Speed Swap DIY
    - B6 USP
    Mar 26 2005
    Quote Originally Posted by biketsai View Post
    GTRS aint a BAT is it? :|
    TEAM|AXION
    Registered User Four Rings CTS Turbo's Avatar
    Nov 12 2008
    01 S4, 04 A4, 15 GTI, 15 S3
    Vancouver
    I think its just a BT
    Jun 05 2008
    B5S4, B7A4
    Its a small BT. K03 flange, "bolt in", stock manifold, ect.. flows about 350bhp. I was told a few times its the biggest turbo you SHOULD run on a Tiptronic. can run it with a lot of the same bolt-ons you'd do for a K03/K04.
    2000 S4
    2008 A4 2.0TQ
    Veteran Member Three Rings kevin12's Avatar
    Jun 20 2007
    01.5 A4 1.8TQM
    South Jersey
    So do we think a 2871r is too much? AudiRacerS4 ran his 2871r with a stock tip other then a tip chip for awhile until he built it with IPT, didn't he? I'm curious because I'm ready to go bt and I know I can go all out I am definitely ready for an upgrade thats more then a k04.
    Current:
    17 Ibis White A3 2.0TQ S-Line
    01.5 Santorin Blue A4 1.8TQ 5-Speed
    Uni 1+, XS Power Exhaust, ST Coilovers, Forge DV
    99.5 Laser Red A4 2.8Q Tip Totaled RIP
    01.5 Casa White A4 1.8TQ Tip Current Parts Car
    08 Ibis White A4 2.0TQ Tip S-Line
    Jun 05 2008
    B5S4, B7A4
    peoples always go bigger anyways. Theres a B6 tip here locally running a GT2871r Elim. on this software daily driver with no problem. Theres also full turbos (not eliminators) tips.
    2000 S4
    2008 A4 2.0TQ
    Jun 20 2007
    01.5 A4 1.8TQM
    South Jersey
    Yeah I know people always go bigger but how are those tips holding up? Thats kinda what I want to know ha
    Current:
    Jun 05 2008
    B5S4, B7A4
    i think its more of a lag issue. unless your gt30+ i dont see your tranny blowing up. but idk.
    2000 S4
    2008 A4 2.0TQ
    Jun 20 2007
    01.5 A4 1.8TQM
    South Jersey
    Thats what I'm thinking. Everyone is always so leary about the tip but I think it can holds it own to a certain limit but I may be wrong.
    Current:
    Mar 26 2005
    There are Stage 3 Tip S4s on az.. i don't think our tranny would blow up if theirs don't.
    TEAM|AXION
    Jun 20 2007
    01.5 A4 1.8TQM
    South Jersey
    Yeah and most of them have had work down to them iirc. Like modified valve bodies, new torque converters, race rebuilds...
    Current:
    Jun 05 2008
    B5S4, B7A4
    i know of a few Stage 3 A6's with only Tip chips on AW regional forum
    2000 S4
    2008 A4 2.0TQ
    Jun 05 2008
    B5S4, B7A4
    $700 for tuning. It is simply flashed in thru the OBD port.
    2000 S4
    2008 A4 2.0TQ
    Jun 05 2008
    B5S4, B7A4
    BUMP!
    getting heater fixed today, then it can start , although my hours at work have begun to be cut
    2000 S4
    2008 A4 2.0TQ
    Jun 05 2008
    B5S4, B7A4
    got my FMIC in last night. w00t
    2000 S4
    2008 A4 2.0TQ
    Jun 05 2008
    B5S4, B7A4
    Hate to revive my old thread but I was wondering if I can run a HFC with the GTRS or do I need a TP?
    2000 S4
    2008 A4 2.0TQ
    Veteran Member Three Rings Fink_tha_Audi's Avatar
    Jun 14 2008
    99.5 Audi A4 1.8t Q
    Middletown, Delaware
    Im running with LaBree's HFC, on my GT2871r, it has good flow and doesnt smell as bad as a TP. Only wish that it was 3 inches all the way. But other than that I love it. Make sure you get a anti-fouler for the post-cat O2 sensor or it your tune is tuned for it.
    99.5 A4 1.8 TQM
    Eliminator GT2871R, UNITRONIC "440cc" tune, FMIC, 2.5" exhaust, SB Stg 4, Gutted LaBree, B&M short shifter, 034 Snub Mount, AWE DTS, LLTEK FR Strut Bar, Synapse DV, SCAT Rods, 034 HF Exhaust Manifold
    Jun 05 2008
    B5S4, B7A4
    Quote Originally Posted by Fink_tha_Audi View Post
    okay thanks. yeah my tune can allow for a TP/HFC. I think the 034 HFC is 3", i might go with that.
    2000 S4
    2008 A4 2.0TQ
