    Veteran Member Four Rings ENDEE666's Avatar
    May 04 2007
    A6 2.7T 6MT Modded. Allroad 2.7T 6MT.
    LI,NY
    Inside door handle trim removal
    I found a few posts about wood trim removal, but does the door handle trim come off the same? I want to be sure before I go prying around & break something... Thx...
    01 A6 2.7T, blk/blk, 6MT, SSP Tuned!, 3,996 lbs w/ me, full weight, street tires, 29+lb wheels.
    Ran an 11.8 @ 119 at MIR - Sept 2008. FIRST A6 IN THE 11's!
    Also 04 Touareg 4.2 89k with 22x10s
    Veteran Member Four Rings 2.slowT's Avatar
    Sep 24 2006
    2002 Audi A6 2.7T
    Minneapolis MN
    Re: Inside door handle trim removal
    Can you post the link for trim removal?
    2002 A6 2.7T Sport
    2000 A4 Avant Daily
    C5UNION | pictures & timeline
    May 04 2007
    LI,NY
    Quote Originally Posted by 2.slowT View Post
    Dont have it off hand but there were several on here as well as Audiworld when I searched. They all pretty much pop off, usually from the rear. Except the pieces by the hand brake.
    Veteran Member Three Rings 4point2's Avatar
    Oct 18 2008
    B7 S4 Avant, KTM RC390
    Vancouver, BC
    May 04 2007
    LI,NY
    Finally doing this & still no idea how to remove the trim around the inside of the door handles.. The area around the handle & the tweeters.. Does it pop off from the front or from removing the door cards?
