Results 1 to 18 of 18
Thread: APR Software
    Veteran Member Three Rings Drew-B6's Avatar
    May 15 2008
    Syracuse, UT
    APR Software
    Ok so I hear about all these problems with APR software! please explain!!! the issue I am having is spark knocking under boost and no one can help me out, It started after I got chipped +1 with TT injectors
    Drew-
    2013 Audi S4
    Veteran Member Three Rings whiteUSPflow's Avatar
    Feb 22 2008
    2004 USP 1.8tQ, 2003 RS6
    Richmond, VA
    Re: APR Software
    i have APR stage 1 what do you mean by spark knocking?
    USP CLUB MEMBER #97
    APR tuned K04-Carbonio-Forge-Podi-Stasis-034 Motorsport-RAI motorsport
    Unitronic tuned RS6
    May 15 2008
    Syracuse, UT
    Re: APR Software
    When I get into boost I start to hear a crackling noise when on the acceleration.
    Drew-
    2013 Audi S4
    Feb 22 2008
    Richmond, VA
    Re: APR Software
    wow never had that happen. to tell you the truth mine has been very reliable, but its still slow as hell.
    USP CLUB MEMBER #97
    Unitronic tuned RS6
    Veteran Member Four Rings rxrep's Avatar
    Feb 28 2006
    has nothing in it but memories.
    Pittsburgh-Philly
    Re: APR Software
    Mine's been very reliable and is as fast as hell.
    My 2004.5 APR Stage 3+ is SOLD
    Veteran Member Four Rings widgget's Avatar
    Dec 18 2007
    nj
    Re: APR Software
    Quote Originally Posted by rxrep View Post
    fast as hell? are you comparing a rock with a iron ball and chain around it?
    Veteran Member Four Rings zemun2's Avatar
    Feb 20 2004
    '04 A4 1.8t FWD APR Tuned
    Zemun, Serbia.
    Re: APR Software
    To the OP, what heat range spark plugs are you using?
    APR Tuned Serbia
    Authorized APR Distributor
    May 15 2008
    Syracuse, UT
    Re: APR Software
    I am using the NGK 6E should I go to 7's?
    Drew-
    2013 Audi S4
    Feb 20 2004
    Zemun, Serbia.
    Re: APR Software
    Quote Originally Posted by Drew-B6 View Post
    Most definitely..
    APR Tuned Serbia
    Veteran Member Four Rings kwimberly's Avatar
    May 03 2008
    Orlando
    Re: APR Software
    I run APR software with 6E's - no problems.
    Kevin W.
    2003 A4 1.8T quattro 5-spd. | USP lower | APR ECU w/ TT225's | APR TIP | test pipe | FMIC | Apikol snub | ecodes | Podi® | AWE sport pedals | JHM SSK/linkage | Forge 007 DV | '02 OEM sport suspension | OEM sport wheels | B6 S4 brakes w/ TyrolSport stiffeners | RS4 rear sway bar| Magnaflow 14829's| AVIC F700BT | hard-wired Passport 9500 | Side-mount trash bag hanging from shifter
    Feb 20 2004
    Zemun, Serbia.
    Re: APR Software
    He runs stage 1+ and that requires 1 step colder range plugs.
    APR Tuned Serbia
    May 03 2008
    Orlando
    Re: APR Software
    Quote Originally Posted by zemun2 View Post
    Ahh. When/if I get my injectors for Christmas I'll remember that!
    Kevin W.
    Veteran Member Four Rings vdubstreets's Avatar
    Feb 20 2007
    02 a4, 97 Gti, 90 wrangler
    ct
    Re: APR Software
    I have heard issues and had issues with stage 1+ on the 02' but with the k04 program I haven't had any real issues.
    Veteran Member Four Rings akaEsCo01's Avatar
    Dec 08 2006
    Jersey
    Re: APR Software
    Quote Originally Posted by widgget View Post
    You are aware he's running APR stage 3 BT right?
    Dec 18 2007
    nj
    Re: APR Software
    Quote Originally Posted by akaEsCo01 View Post
    nope, figured he had 1+ like the OP since it wasn't mentioned.
    May 15 2008
    Syracuse, UT
    Re: APR Software
    Thanks for the help I will try the 7's and see if that fixes the problem. I plan on going K04 when I have the funds available.
    Drew-
    2013 Audi S4
    Junior Member Two Rings K1200GT's Avatar
    May 10 2007
    Re: APR Software
    Mine works great, see below. I also have the R coilpacks:
    2017 A4 Quattro CYMC
    2022 Audi A5 Sportback 40 Miller cycle (Wifes car)
    2011 Audi A4 Quattro stock SOLD
    2002 Audi A4 1.8turbo Quattro Tiptronic SOLD
    APR 93 chipped
    BKR7E's, 710N
    Bilstein HD dampers (struts)
    K&N panel filter, modified stock airbox
    Veteran Member Four Rings A4SoftWalker's Avatar
    May 13 2008
    Avant 03A4 1.8TQMS, 05V70R, BMW535i
    NoCal - EBay
    Re: APR Software
    ^^OP what are ur mods u are @ a distinct disadvantage to running without pinging without an intercooler and turbo/catback exhaust. The sparkplugs will help a bit but look to supporting mods too in the future. Gud luk.
    See also:
    http://www.audizine.com/forum/showthread.php?t=247652
    'SOFTWALKER MODS
    Do U have a Bentley/Dealer Manual & Tools to work on UR car properly?
    Hit-or-miss expecting manna to fall from AZ?
    Personal Motto>Walk Softly Carry a Big Stick. YEAH I'M BACK!
    BUILD? Click & be Amazed!
    Avant>Sedan! Click
