Results 1 to 17 of 17
    Veteran Member Four Rings Euro-Tuner's Avatar
    Jan 06 2007
    NH
    Unhappy I though anodized metal didnt scratch?
    ...my ER Comp FMIC hot side pipe
    I don't suppose ER would reimburse me on such a thing would they? *wink wink*
    Jun 04 2007
    01' A4 1.8TQM;15' Wrangler
    Austin/DFW, TX
    Re: I though anodized metal didnt scratch?
    Lol, what did you do there?
    BetaAlphaTau Member #12
    01' A4 1.8TQMS 5spd swapped
    My 5-Speed Swap DIY
    - B6 USP
    Jan 06 2007
    NH
    it was against my frame rail, I guess they just said, "fuck it, that's close enough"
    the fitment was always hokey looking to me but I didn't know it would do that...
    Feb 27 2005
    North Wales, PA
    i guess weld that hole up and cut that sharp point on the frame rail. That sucks man.
    Veteran Member Three Rings 1NaudiA4's Avatar
    Feb 13 2007
    98 A4
    Chicago
    I have the same problem with my IC pipe though its not from ER and it didn't go through. I slipped a silicone coupling right over where it was rubbing against the frame rail so it wouldn't cut through and its been good since.
    Jan 06 2007
    NH
    ^^I'd keep an eye on it, if its pushing hard enough it'll go right through that silicone.
    I cut that part of the frame rail tonight, it was nothing vital, just the pinch weld that was on the piece that goes from the frame rail to the passenger fender right in front of the wheel well.
    Feb 27 2005
    North Wales, PA
    i had that issue with my diverter valve. I groove a line right through billet aluminum. I just ground down that pinch weld and welded in a flat.
    Oct 27 2007
    2001 Golf 2004 A4 USP
    In the lab
    Wow lol!
    Feb 09 2007
    00 S4
    MA
    jesus christ! that car hates you.
    Buy tools, not labor....
    00 Audi A4, 1.8TQ avant, 6-speed swapped (from auto), s4 brakes, uprights, cluster, grill, OEM bmw style 162 wheels, slammed.
    95 BMW M3 drift car: OBD1 S52, gutted, tubed, flares, angle.
    Feb 15 2008
    E46 323i 5-Sp
    616/MI
    I've had customer's do that w/ A/C lines too. They never thought a cheap intake would cost soo much in the long run.
    Mar 09 2004
    99.5 A4 Avant, 01 allroad
    nw michigan.
    Anodize isn't much more than a dye. It protects the aluminum from oxidation and gives it a bit more surface hardness but it is like an eggshell - hard on the outside but as soft as ever inside.
    Jim
    I Do Werk.
    Registered Member Three Rings
    Aug 14 2008
    Salt Lake City, UT
    plus, a lot of mandrel bent aluminum is annealed so that it bends well, and then never heat treated back to T651 or whatever it was before. Usually T6. Anyways, this makes it extra soft and flimsy.
    I still run it though, steel is just so damn heavy.
    Integrated Engineering LLC
    Your source for fine quality VW/Audi Connecting rods and engine hard parts. Applications including: 1.8t, 8v, 10v, 20v, V6 and V8...
    www.intengineering.com
    Jul 07 2004
    630AWHP A4, Nissan Titan
    socal
    Was that the standard ER hot side pipe or the one they make for the Full-race setup?
    The standard pipe is designed for a Elim with the outlet facing downward and the other version is for a top mount turbo that has the outlet facing toward the fender.
    Jan 06 2007
    NH
    ^^ I'm not sure, I assumed it was for the Full-Race setup b/c thats what I told them when I ordered, do you have any affiliation with ER?? YGPM
    Quote Originally Posted by onemoremile View Post
    ..it was kind of a joke, but I'm not very funny on the internetz
    Registered User Four Rings
    Feb 26 2006
    Over 20! too many plant pots!
    Earth
    Get some chewing gum
    it will be fine.
    Jul 07 2004
    socal
    Quote Originally Posted by Euro-Tuner View Post
    Polished FMIC, black anodized pipes with hot side IC pipe for top mounted turbo.
    Mar 09 2004
    nw michigan.
    JB Weld it.
    Jim
    I Do Werk.
