Results 1 to 12 of 12
    Mar 18 2008
    Palmer Lake, Colorado
    Changing to winter tires, have a ???
    I bought 4 used 195/60/r15 hankook winter tires. The tires on the rims currently are 205/60/r15. What problems if any would I have if I put on the 4 winters, leave my spare a 205/60/r15 and just used it if I got a flat. Thanks Palmer
    palmerlaker
    2001 A4 1.8tqm stock
    Veteran Member Four Rings 99blueb5's Avatar
    Mar 10 2008
    01 S4, 99 A4
    Bellevue, WA
    Re: Changing to winter tires, have a ???
    nothing, they are the same profile so your speedo wouldnt be off, only difference is that the winter tires are a little more narrow
    99 A4 1.8TQM:
    APR Stage 3 GT28rs kit, CM FX400 6puck, 3" downpipe, Nuespeed catback,Nuespeed short shift, Cxracing fmic, Forge007 DV, H&R coilovers, APR snub mount, gasket ported head, VDO guages, e codes, 6k's, Fiberimages CF hood/trunk, A8 BBK, IE Rods
    00 B5 S4
    Vast stage 3, Rs4 airbox, ko4's,borla cat back, neuspeed sways, statis coils, jhm fmic, SSAC Dp's
    Dec 20 2007
    1999.5 Audi A4qm AEB
    iowa
    Quote Originally Posted by 99blueb5 View Post
    Incorrect, the sidewall is 6mm taller on the 205 than it is on the 195 basicly the same as mounting a brand new tire with three with half tread. It's not recomended to have different sized tires on an AWD car due to the clutches in the diffs although 6mm isn't much.
    Mar 10 2008
    01 S4, 99 A4
    Bellevue, WA
    Quote Originally Posted by Toyotatech View Post
    i dont agree a 205/60/15 tire measures 24.21 inches tall, a 195/60/15 measures 24.68inches tall so .47 inches of difference really not that much difference, and ask anyone, when you are driving through snow the less width the tire has the less snow it has to compact thus making the tires easier to roll though the snow, i have done this exact winter tire swap to 4 a4's and havnt had any problems
    99 A4 1.8TQM:
    00 B5 S4
    Dec 20 2007
    iowa
    The 6mm is on each sidewall giving it a 12mm larger overall diameter which is 1.2cm making it 0.47244094488 inch. I didn't argue that a more narrow tire will cut through snow better I said to use the spare may cause differential clutch problems. I disagreed with you because you said they are the same profile or overall size which they are not. Although they will not make MUCH of a difference on the speedometer you were also wrong in saying your speedometer wouldn't be off.
    If it was my car and I got a flat I wouldn't mount a different sized spare on even though there probably wouldn't be any problems with it in this case.
    Mar 10 2008
    01 S4, 99 A4
    Bellevue, WA
    Tire Width - The width of the tire tread. (e.g. on a 255/55/16 tire, the width is 255).
    Aspect Ratio - The ratio of tire sidewall height to tire tread width. (e.g. on a 255/55/16 tire, the AR is 55).
    Rim Diameter - The diameter of the rims. (e.g. on a 255/55/16 tire, the rim is 16 inches tall).
    Tire Diameter - The total diameter of the tires. This is the height from the bottom of the tread to the top of the tread (if the tire is standing).
    and yes i would'nt use the spare too but if i was in the middle on no where i would
    and the speedometer will only be off 1.16mph which you would never notice
    99 A4 1.8TQM:
    00 B5 S4
    Dec 20 2007
    iowa
    Thanks for the lesson on tire design only I already learned that in schoollong ago and didn't have to google it like you.
    Mar 10 2008
    01 S4, 99 A4
    Bellevue, WA
    hahaa there is alot of cocky people on this forum... i got that from a automotive calculator website that can convert sizes, pretty sad that i am teaching people on here the basics...
    99 A4 1.8TQM:
    00 B5 S4
    Jul 22 2008
    Dallas, TX
    Rule of thumb is 2-3% difference in tire size won't mess things up, so you should be fine. You guys get any snow yet? It was 70+ here in Golden on Monday. I want some snow bad, need to get the full quattro effect
    Mar 09 2004
    99.5 A4 Avant, 01 allroad
    nw michigan.
    You will be fine.
    Jim
    I Do Werk.
    Mar 18 2008
    Thanks for the info guys, I'm still looking for an additional 195/60/r15 to throw in the trunk. Everyone is selling pairs or all 4. Just wanted to make sure I wasn't going to tear anything up if I had to use the 205 spare at some point.
    palmerlaker
    Mar 09 2004
    nw michigan.
    There is a range that is acceptable. Otherwise the still new spare tire wouldn't work with new tires and very worn tires.
    Jim
    I Do Werk.
