Results 1 to 10 of 10
Thread: Leak~
    Veteran Member Four Rings le91688's Avatar
    Jun 20 2008
    2000 A4 2.8QM
    Pordenone, Italy
    Leak~
    So lately whenever it rains, the floor behind and under the drivers seat gets SOAKED with water and it doesnt seem to let up. I did some searchin and found out about the problematic sunroof drain plugs, and i found the DIY on audiworld of how to unclog them. The problem is this involves removing the rear bumper, and im not sure how they would be the problem if they drain behind the rear seats.
    Anyone have any ideas as to what this water problem is being caused by? I did run power wire through my firewall where the hood latch cable comes through, and i will check it out tomorrow in daylight, but im thinkin maybe its the front drain plugs from the sunroof.
    __________________
    Jan 19 2008
    Re: Leak~
    From what I've read, it's a problem with the drains in the engine bay behind the fake firewall (where the battery is).
    Edit: nevermind.. You said under and behind your seat.
    Veteran Member Four Rings arorem's Avatar
    Mar 24 2008
    '99 A4 1.8TQ, '74 Triumph Spitfire
    Illinois
    Re: Leak~
    maybe a plug under the car has rotted away? Happened on my jetta.
    Jun 20 2008
    2000 A4 2.8QM
    Pordenone, Italy
    Re: Leak~
    plug under the car?
    __________________
    Apr 25 2007
    millersville, maryland
    Re: Leak~
    do you park on a hill ?
    Jun 20 2008
    2000 A4 2.8QM
    Pordenone, Italy
    Re: Leak~
    no
    __________________
    Veteran Member Four Rings zrowcool's Avatar
    Nov 09 2006
    2000 B5 A4 Quattro / 00 F-150 XLT S/C
    Bronx, NY
    Re: Leak~
    you dont have to take off the bumper. the hose that runs from the sunroof goes right behind where the cd changer would be if you have one equipped. its like a orange browinsh color. just pull it off the grommet and make sure its clear. sounds to me like it may be off the grommet and just draining into your car instead of outside
    2000 A4 1.8tq
    Running only on Amsoil fluids.
    Amsoil products at wholesale pricing... Ask me how!
    Veteran Member Four Rings lowandslow4now's Avatar
    Jul 12 2008
    Cumming, GA
    Re: Leak~
    I had the sam issues I had run a line from where the hood latch cable runs in and the carpet was getting soaked in the rain. I used some sealant on the rubber around the hood cable and it stopped.
    Now 2001 B5 S4
    Former B5 A4, 034 Stage 3 BT, Unitronics,H&R,etc,etc
    Veteran Member Four Rings 01audia4's Avatar
    Jan 31 2008
    Philly home of the cheesesteak
    Re: Leak~
    Take out the battery, there is a drain in there, clear that out.
    2001 A4 2.8-->1999 a4 1.8tq 220K-->2000 K04 S4--->2001 F21 S4 eating corn w/ stock rods
    Jun 20 2008
    2000 A4 2.8QM
    Pordenone, Italy
    Re: Leak~
    Quote Originally Posted by lowandslow4now View Post
    I ran my power wire for my subs through that hood cable... I'll seal that bitch up today :)
    __________________
