Results 1 to 7 of 7
    Veteran Member Four Rings vtracer20's Avatar
    Apr 14 2008
    Milton VT
    FORGE DV + AWE vent gauge ?
    Anyone have this setup? Forge includes a 3 port t-fitting and awe's is single..just wondering how you got both of them to fit in the location of the intake manifold closest to the firewall. That's where your suppose to tap in.
    I'm currently using the forge t-fitting to provide source for the awe gauge but i'm getting the rattle...so i'm gonna use both the forge (need it for source of the dv) and awe's (source for gauge).
    Just wondering how you guys made it fit...any nice looking setups. Thanks
    2007 A4 S-Line / Ti Pkg / Quattro / Bilstein Pss9 / JHM Short shifter / GIAC X+ chip / RS4 rear sway bar / 20% rear tint / 10mm front 15mm rear spacers / Forge DV / DTM CF replica rear lip spoiler / DTH CF roof spoiler / Cupra R front spoiler (not on) / Infinity BasslinkII sub
    looking for: CF front lip / S4 alum mirror hosing
    Veteran Member Four Rings Slo.Mo.Shun.'s Avatar
    Oct 14 2006
    MK6 Jetta
    South,FL
    Re: FORGE DV + AWE vent gauge ?
    I cut off the AWE T fitting and put it inside the vacuum line that feeds in to the gauge.
    -Unitronics Stage 2+ ECU/TCU tune.
    -EI AL CAI.
    -Driver Mod.
    Apr 14 2008
    Milton VT
    your talking about the nipple with the little metal piece in that?
    Oct 14 2006
    MK6 Jetta
    South,FL
    I cut the nipple off with a rotary tool.
    -EI AL CAI.
    -Driver Mod.
    Apr 14 2008
    Milton VT
    your not getting a rattle out of the boost gauge?
    Oct 14 2006
    MK6 Jetta
    South,FL
    Quote Originally Posted by vtracer20 View Post
    Not at all.
    -EI AL CAI.
    -Driver Mod.
    Apr 14 2008
    Milton VT
    i'll give it a try after work....damn it's annoying
