Guys:
Audi actually has a Technical Service Bulletin (TSB) on this problem which states the glove compartment cover brake element is FAULTY...this is NOT nromal "wear and tear" and you should've have to "go easy" on your glove box door, for crying out loud. Anyway, it's TSB 68 08 10 2012801/3, and it states it applies to the following vehicles:
- A3s (2005-2006)
- A4s (2002-2006)
- A4 Cabriolets (2003-2006)
- A8s (2003-2006)
I can't post the Copyrighted TSB. However, I had ALREADY deduced on my own that the faulty glove compartment door damper was causing me to pull open the door every time and was possibly damaging the door hinges.
If your glove compartment door isn't opening anymore or requires you to pull it open by hand, bring it to your Audi dealer before you reach 12 months/12,000 miles on your vehicle. State you are having trouble getting the door to open and have to pull on it excessively, and request warrantee service. After 12/12,000, they will NOT fix it, because it's considered "interior trim"...ridiculous, I know, that Audi thinks it's okay their glove compartments can fall off after 12 months at customer expense.
One has to buy a new glove compartment and/or glove compartment door to repair this because the hinges are integrated with the part. I'm afraid to even ASK what they charge for a new glove compartment door or the entire compartment!
So much for high-quality German engineering...lol. What galls me about this is that it's been a KNOWN faulty issue for a while, and they didn't send out any notices to any Audi owners who might've had the problem and not realized it wasn't a "feature"...and who could've fixed it before the "interior trim" warrantee expired.
If you develop this problem with your glove compartment door and don't get it fixed before 12 months/12,000 miles then you're screwed! I'm not sure if there's a way to lubricate the faulty brake/damper element to prevent the excessive slowness...
By the way, here's a link to the post from a guy who says he found replacement door brakes and fixed this for an earlier model Audi...not sure which cars this would work for, or what the part numbers would be for the new, improved dampers Audi is supposedly using now:
http://forums.audiworld.com/a4gen2/msgs/967087.phtml
Regards,
Bill
