Results 1 to 6 of 6
    Veteran Member Four Rings njm23's Avatar
    Feb 28 2007
    04 a4 USP ; ATS
    Guys who know the 20v head..
    Alright, I am pulling apart my AEB head tonight. Got one question, can I re-use my lifters or should they be replaced? Putting valves/springs/retainers in and am questionable on the lifters. Head will be gone for 2 weeks or so so it is nothing I need tonight so i figured while I have sometime to think..Or should i wait till I throw my cams in about 6 months when all is said and done?
    Jan 25 2006
    A4 2.0T
    MD
    Re: Guys who know the 20v head..
    As long as you are using the same cams and the current lifters are not damaged then you should be fine... just give them time to settle before you start the car.
    Oct 27 2007
    2001 Golf 2004 A4 USP
    In the lab
    Quote Originally Posted by Don Supreme View Post
    Couldn't have said it better myself... And I emphasize on the bolded part
    Feb 15 2008
    E46 323i 5-Sp
    616/MI
    What THEY said.
    + when you install a performance cam you should replace the lifters.
    EDIT: dammit jake you beat me this time.
    Oct 27 2007
    In the lab
    Quote Originally Posted by djwimbo View Post
    What THEY said.
    Payback ho
    Feb 28 2007
    04 a4 USP ; ATS
    haha alright, thanks for the quick replies. Glad my garage is heated, f-in 33 degrees out here.
