Results 1 to 14 of 14
    Rest in Peace Four Rings adam's rotors's Avatar
    B9SQ5 | B9S4 | HD FXLRST
    whats the best way to install glue/tape on sideskirts?
    [posted this in general car chat as well...thought maybe some locals can help me out or have done this before]
    just got me some OSIR sideskirts for my 8P A3
    they are 100% glue or tape on fiberglass skirts...no holes or tabs
    there is a small grove that somewhat latches onto the car but is more of a lip just to hang onto the OEM sideskirt a bit cleaner
    im dropping them off to paint today and need to know whats the best adhesive or tape or both to install when i get them back
    obviously need something sturdy/strong that will last and not fall off...
    plus keeps its tight and flush with the car...
    quick drying, sticky, withstands weathering and vibration, etc...
    any thoughs/tip/experiences/recommendations?
    thanks guys!
    adam | adam's rotors inc. | [email protected] | est. 2006
    customizable factory-fit brake rotors, made-to-order | adamsrotors.com
    follow/like/@/tag @adamsrotors on twitter, instagram, & facebook | #adamsrotors
    Senior Member Two Rings fapodaca's Avatar
    Dec 03 2007
    2014 AUDI RS5, 2013 GMC SIERRA, 1989 BOX CHEV
    DISCOVERY BAY
    Re: whats the best way to install glue/tape on sideskirts?
    i used to install all oem audi body kits, go to a auto gass company and buy a tube of the urethane adhesive. from them and use a standard chalking gun. but the key is after the install, let it cure/dry for 24hrs, then no wash for 48hrs, then no load/driving for 72hrs.
    follow these 4 steps and you'll be happy. if not they will peel off in time call me for any questions....
    and of course i can assist with install if needed.........
    Freddie
    Freddie Apodaca J.R.
    East County European AutoWorks
    thanks...PMd you
    anyone else?
    Veteran Member Three Rings Elohite's Avatar
    Jan 14 2008
    San Antonio, TX
    If you want to go Tape
    Of course clean both surfaces with rubbing alcohol before you apply the tapes
    Home Depot sells 3M VHB (Very High Bond) Double Sided Tape, (Grey Tape with Red Peel). Its pretty strong and I used it to support my DD 350z sideskirts for over a year.
    Another Glue method alternative to Freddie's would be Epoxy. But if you go with glue I might go with that Freddie stated as I bet he has more experience than me and that stuff sounds more adhesive than epoxy
    Cons of the glue method is that if you ever remove or decide to change it might damage one or both parts but its gonna hold well.
    Tape will be easier to remove and will hold onto it well but you'll feel more secure with a glue method.
    -J
    Edit: Not sure but it having a body shop riveting it in a possibility?
    Garage Inc | APR | Britalman | 034| Stasis | Volk |Rotora | Deval | EuroGear | DTH | Thule | Forge | BSH | AWE | Evoms | H&R | Pioneer | JL Audio | TMA | ZiZa | KLight
    ^ yeh ive been researching and found the VHB stuff
    i think tape is easier and less scary/messy
    plus i dont have that 24-72hr option...its my car u know?
    im gunna pick some up unless i hear back from freddie about this...
    Jan 14 2008
    San Antonio, TX
    Yeah. GL with the Tape project.
    Theres no reason why it shouldn't hold with a good amount and proper cleaning
    Nov 19 2005
    Pair of (. )( .)
    damn, Adam, i didn't realize you have an A3 now....! where are the pictures of that bad boy?
    -Andrey
    Stanced and Tuned Brilliant Black RWD C5 A6 2.7T 6MT
    Veteran Member Four Rings downhillracer's Avatar
    Aug 20 2007
    97 Jeep Wrangler
    Costa Mesa / Mammoth Lakes
    Whats up adam! Good luck with that install, I really like the look of those skirts!
    Quote Originally Posted by kievskiy View Post
    ...and you might be seeing it on a certain homepage sometime soon
    Feb 10 2004
    2009 A4 2.0T Sedan
    So you decided against the OEM S3 sides huh?
    We used the adhesive that Freddie's talking about, for the Votex sides on my brother's A3. They held on great, but the extra tabs on the bottom and the screw on the one end helped too. Getting the glue off when we were demodding was a PITA, but we did it.
    I'd be a bit worried using tape alone, especially the way you drive.
    ^ too much! theyre ~$700-800 without paint!
    AND i decided to have the body shop do it...
    i was fighting for $200 for paint...they wanted $250
    so i said fuck it and offered $300 for paint AND install and they took it
    let them deal with it
    well see
    these are just as subtle as votex, but a bit less aggressive then s3's...
    my main concern is a subtle look that doesnt hang lower then the front and back
    the sides just need some beef
    Feb 10 2004
    2009 A4 2.0T Sedan
    Good idea. And damn, the S3s are bank! Man I wish you woulda taken the Votex ones I still have sitting in my garage...
    Veteran Member Four Rings norcatalyst126's Avatar
    Galt, CA
    Soooo....where are the pics Adam????
    need rotors?...adam's rotors
    i have to get em on first son
