Results 1 to 11 of 11
    Veteran Member Three Rings 2k1audiS4's Avatar
    Oct 30 2007
    Pasadena, MD
    Tapping sound this morning.....
    This morning it was 24 degrees out when I started the car and I noticed a tapping sound comming from the motor. Im guessing that it is the lifters getting going but I just wanted to see if there is something else that I should be worried about. The sound went away by the time I got to work (35 min drive). Oil level is good. This is the first winter I have had this S4 and I cant remember ever hearing it from the other two. Anything big I should worry about?
    2001.5 S4 Silver 6MT......GIAC X, APR Bi-Pipe, FMIC, "Custom" UUC VM1, RS4 Clutch, APR R1 DV's, AWE DTS, K&N, Eibach pro kit, D3........SOLD
    2000 S4 Black 6MT.....Stock........SOLD
    2000 A6 2.7T 6MT.....Stock..... SOLD
    2001 S4 Sport Black 6MT.....Stock......SOLD
    2001.5 S4 Santorin 6MT....Stg2.....SOLD
    2001.5 S4 Sport Santorin 6MT....Stg2....SOLD
    2001 S4 Sport Silver 6MT.....Stg1....ACCIDENT THEN SOLD
    Oct 31 2005
    Ashburn
    Re: Tapping sound this morning.....
    Lifters will sound alot louder in the colder weather.
    Just like my old DSM, faint in the summer, firecraker in the winter.
    well aleast that's my prospective
    - Instagram: @Sinister_rs5-
    Senior Member Two Rings nocturnals4's Avatar
    Dec 10 2007
    '00 S4, '94 Z28
    P-dena,Maryland
    yea you'll be alright...you still coming by tonight for the bearing?
    Oct 30 2007
    Pasadena, MD
    Quote Originally Posted by nocturnals4 View Post
    Yup, as long as your still up for it. 5:30 right? Did you say you did or didnt have a compressor that I can use at your place this weekend? I can bring mine if not.
    Dec 10 2007
    '00 S4, '94 Z28
    P-dena,Maryland
    5:30 and I have a compressor at home
    Veteran Member Four Rings 1997gtx's Avatar
    Sep 14 2006
    14 GLI
    Normal.
    Have questions? E-mail me.
    Apr 11 2008
    00 s4 90 crx
    High Point, NC
    Like other have said, thats pretty normal. What weight and brand oil are you running?
    2000 Brilliant Black S4
    -DNA Catback, Piggies, Darintake w/ITG panel filter, 710n's, 034 TBB, 034 F hose, Vast clutch, JHM shifter & bushings, Vogtland/Koni's, Hotchkis Sways, ECS 12.5mm spacers
    2010 Honda Civic Ex Sport Auto
    -Stock daily driver/panty dropper
    2014 Fiat 500 Sport
    -Stock cone dodger for now. Suspension coming soon.
    Veteran Member Four Rings haus4's Avatar
    Apr 27 2008
    silver s4
    LI
    its normal, my uncles 4000 with the 5 cyl was really bad in the winter. Sounded like some one with a small hammer banging on the valve covers.
    Try a different weight oil/different brand to see if that helps the noise.
    Veteran Member Four Rings tike0rz's Avatar
    Apr 17 2007
    B8 A5
    Thanks for making this thread.
    I also began to hear a tapping early this week, when it was roughly 40 degrees.
    What oil weight is recommended?
    Sep 14 2006
    14 GLI
    ^ 0 or 5
    Oct 30 2007
    Pasadena, MD
    Quote Originally Posted by sCeRaXn View Post
    I think I have 5-10 mobil one in there now. I would have to look at the case when I get home though to be sure. I have put about 2k miles on it since the last oil change.
