Results 1 to 3 of 3
    Established Member Two Rings Brav's Avatar
    Aug 27 2007
    64 Riviera, 2010 RR S/C
    Huntington Beach, CA
    Low voltage, then dead battery
    I noticed that my car was running around 11.8-12V, and recall it being close to 14 most of the time while driving. Now it wont turn over. My first inclination is to replace the alternator. Is there anything else I should check first?
    Also not sure if its related, but the headlights sometimes wont turn on and I ahve to cycle it several times, and i get an intermittent brake light out warning. I think the brake light is the socket, as is usually the case..
    2016 A6 2.0T Quattro
    Aug 06 2008
    Canadia
    Re: Low voltage, then dead battery
    sounds like a dead alternator. if your going to get a re-man, try and find someone local eho rebuilds alternators first. just as good and cheaper.
    the B5 S4 is like the mafia... there is only one way out!
    May 18 2007
    01 Laser Red 6MT, 13 Touareg TDI
    Baytown, TX
    autozone ftw with alternators... lifetime warranty. if it dies again, then they replace it for free... well, plus your labor time.
