Results 1 to 13 of 13
    Veteran Member Three Rings nrowensby's Avatar
    May 04 2008
    1999 Porsche Boxster
    Columbia, SC
    Let's See Your Single-Din Aftermarket Install....
    Trying to figure out how to get my Alpine IDA-X100 to look a bit better in the dash... How'd everyone go about mounting your radio? Pictures and details please! :D
    ▄▀▄▀▄▀▄▀▄▀▄▀ B8.5 Squad ▄▀▄▀▄▀▄▀▄▀▄▀
    2014 Audi A4 - Stg2 - Monsoon Gray Metallic
    2015 Audi A4 - S-Line - Ibis White
    Established Member Two Rings Accel's Avatar
    Jan 30 2008
    Vancouver
    Re: Let's See Your Single-Din Aftermarket Install....
    I'm probably getting this headunit, what does it look like in your car? Lets see a picture?
    Apr 22 2007
    Riverbank, Ca
    Veteran Member Four Rings Jibberific's Avatar
    May 22 2008
    az
    here's mine...
    For some reason, my head unit was mounted kind of deep in the dash, like it's kind of behind that instrument panel. So since it fits all weird, there's a huge ugly gap around it. I want to clean it up by installing some kind of bracket or mounting plate to make it fit correctly and get rid of the gap. Do any of you guys know how i should go about this? Is there a kit i can get?
    {99.5 Avant}
    Veteran Member Four Rings goody6691's Avatar
    Feb 23 2005
    Elkton Md, B.A.T certified
    i love mine, lights match the dash. i-pod only is great untill a friend gives you a disk to try out.
    too much shit to list
    Dave
    it runs bitches..............im back
    98.5,Brilliant Yellow, Audi ,A4,Quattro, 2.0, je, eagle, cat cams, tial, hta3076r, tap 630, CCW Classics, Falken,SPA, Autopower, Sparco
    Feb 15 2008
    E46 323i 5-Sp
    616/MI
    I changed mine up a bit. I removed the ash tray and I will be putting two gauges down there and an OE style 12V power outlet. At least I'm pretty sure they'll fit.
    I wanted to put the HVAC unit down there, but I got ahead of myself on the trimming and it didn't work out like planned. Either way, here's how it looks as of Saturday.
    Note: Head unit is a Sony GT500 (>2yrs old) and matches the gauges and OEM lighting about 98%. The only reason why I have kept it for so long.
    Jul 22 2008
    Dallas, TX
    What ever you do, don't get the Scosche one from Crutchfield if you have a facelift car
    Veteran Member Three Rings B5Burn's Avatar
    Feb 25 2007
    1998.5 A4 2.0BT
    Winnipeg, Manitoba Canada
    Has anyone ever built a 'cover' of any sorts for the centre console? I HATE, the surround around an upgraded H/U. Have it myself.. hate hate hate.
    Looks like an easy to make something for.....
    B.
    May 04 2008
    Columbia, SC
    Here's mine... extremely happy with the radio... not so much with the look of the dash kit.
    Night... looks great!
    Dusk... Still looks good.
    Day... Dash kit kills it :(
    May 22 2008
    az
    Quote Originally Posted by nrowensby View Post
    Looks a hell of a lot better than what i have going on, nothing at all! Where did you buy the dash kit?
    {99.5 Avant}
    May 04 2008
    Columbia, SC
    Registered Member Two Rings 4BLKRNGS's Avatar
    Oct 22 2008
    Monrovia, MD
    i kept the stock head unit and just wired up a 4 channel 1200 watt amp for the speakers and changed all those out and then added a 2000 watt mono channel amp for the subs and then i spliced the wires from the head unit and then got an adapter so i could convert them to rca and then wired them to the amps so it all worked out just a lot of wiring but i get to keep the stock look with 6 cd changer. i would have gone aftermarket head unit like alpine but the damn stock head unit is really long so all the after market ones look stupid. here are 2 pics.
    <center>
    <img src="http://i470.photobucket.com/albums/rr61/4blkrngs/1002081407.jpg" alt="Photobucket - Video and Image Hosting"><br><br>
    <img src="http://i470.photobucket.com/albums/rr61/4blkrngs/1104081137.jpg" alt="Photobucket - Video and Image Hosting"><br><br>
    </center>
    Feb 15 2008
    E46 323i 5-Sp
    616/MI
    Quote Originally Posted by B5Burn View Post
    I have no idea where I found it, but I found somebody that took the trim bezel around the face plate and molded it into the OEM trim piece. It takes a bit of effort and some trimming of the OEM piece, but it looked good afterwards.
    Here's some non-B5 motivation to show you some of the cool things you CAN do.
    Before:
    AFTER:
    You have no idea how many pages I had to look through to find that, hope you appreciate it.
