Results 1 to 15 of 15
    May 01 2008
    Las Vegas
    N 75 valve going bad,misfiring ingnition coils...
    My N75 valve is going bad and also ALL four ignition coils are misfiring. EXPENSIVE! I'm pretty new to Audi and cars in general. I was wondering if anyone had any advice on these things I already got a diagnostic but im not payin 1200 for these things to get fixed at eh dealer. So i'm thinkin about doing it myself. Anybody got some advice or suggestions. maybe a DIY?
    My names Chris I got a Denim Blue 02 a4 55k miles. HOPFULLY SOMEONE CAN HELP ME OUT!
    Veteran Member Four Rings LampyB's Avatar
    Apr 25 2007
    MA
    Re: N 75 valve going bad,misfiring ingnition coils...
    The N75 isn't hard to replace, just a pain in the ass. Getting rid of all the one time use OEM clamps sucks a fat one, but other than that it's really just unplugging the attached wiring harness and several vacuum lines. might take you a while if you haven't been in there before. oh and the passenger side headlight will need to be taken off as well, but that's the easiest part!
    what symptoms of a bad N75 are you having? just buy 4 new ignition coils for under $130 online and replace them yourself...literally takes ten mins. and can even be done while stuck on the side of the road. the N75 is around $90 at mjmautohaus.com, as well as the coil packs. do a search in the forums for a DIY install.
    Custom Trunk Badges For Sale!
    | 2004 A4 USP 1.8TQ | 6SPD | GIAC 1+ | APIKOL | HYPERBOOST | FORGE TIP | NGK | 20% TINT | VMR | OFE SS | PODI | N249 Delete |
    May 01 2008
    Las Vegas
    I went to the dealer and got a diagnostic. That the ONLY reason I know whats wrong haha.
    Im getting some loss of power, rpm's and boost gauge go up and down a little if i go past 2800 rpms even if im not flooring it. Its retarded. still drivable, but annoying. in your opinion do you think i should upgrade the N75 or would it be a waste of time? I am planning on moding my car more soon...& thanks for replying I didint think i was gunna get one for a while.
    Is that your clothing co.? the jacket's pretty sick
    Veteran Member Four Rings A4 Moda's Avatar
    Jun 11 2005
    2003 Audi A4 1.8TFSM
    SoCAL- City of Industry
    What does the code say?
    if it's "random misfires" in all 4 cylinders,
    chances are it's your MAF.
    GL
    Eurocode TINY Turbo GT71R Eliminator:: REVO Tuning::
    2003 1.8T
    Eliminator||Carbonio V2||ATP EXhaust Manifold ||Neuspeed TIP (Eurocode)||JOE P MBC @ 22PSI B9- Timing 5||Custom 3" Exhaust||Mangaflow Mufflers|| Revo||Reiger||Boser hood||S4 Bixenon Ecodes||LED Tails||Eibach Coilovers||
    Jun 08 2008
    Calgary AB Canada
    there no way any of that would cost $1200.
    Do oyu have the actual codes they read?
    If all 4 cylinders were misfiring, chances the car would run like absolute crap or not run at all. Like A4 Moda said it could be a MAF problem or even a boost/vacuum leak.
    May 01 2008
    Las Vegas
    i was tinking it was a vaccum leak too i specifically told the dealership to check that out but they just said those two prblems...whats your MAF? and what does it do? how can i check to see if its that. they didnt give me the codes..
    Veteran Member Four Rings BNZ TOY's Avatar
    Oct 29 2006
    1G FX35, 03 R6, B6 A4 MT6
    Vancouver
    Ppl always say to unplug the MAF and see if that makes it better. If it does, then it's your MAF.
    There is someone in the classifieds selling a MAF for 40 shipped.
    Another silver B6
    Go/Stop: K04-015 ~ Intake/TIP ~ Forge Splitter ~ Neuspeed turboback ~ B&M SS ~ H&R Sport w Bilsteins ~ S4 Sways ~ Eurocode FMIC ~ 245 Rotors/18z ~ FX300 240mm LWFW ~ Snow Meth Inj ~ EURODYNE tune
    Flair: USP Front ~ Cupra R ~ S4 Trunklip ~ Euro Roof Lip ~ VMR v710 235/19/35 ~ S4 doorblades ~ B7 rear valance ~ LED fogs ~ B7 DTM skirts ~ Euro RS4 Steering Wheel ~ S4 Recaros
    Veteran Member Four Rings downhillracer's Avatar
    Aug 20 2007
    97 Jeep Wrangler
    Costa Mesa / Mammoth Lakes
    Upgrade your diverter valve! (n75 valve) There is a group buy going on for forge 007 diverter valves right now, get one of those instead because a new oem n75 will just tear the internal diaphragm again, especially when you start doing mods!
    Link to GB on 007 valve:
    http://www.audizine.com/forum/showthread.php?t=174190
    Veteran Member Four Rings Howard Hughes's Avatar
    Feb 17 2004
    1.8T Revo3 Q-Tip
    Chicago Illinois
    Quote Originally Posted by downhillracer View Post
    N75 is not your DV...
    789whp
    May 01 2008
    Las Vegas
    Wheres my MAF and how do I unplug it to see? && what would I be feeling if my coils were misfiring? because if its ALOT I def. dont feel it. Just the loss of power and boost...
    Jun 08 2008
    Calgary AB Canada
    MAF is your mass air flow sensor, its plugged right into the airbox.
    Veteran Member Four Rings FORCE_FED_DUB's Avatar
    Aug 10 2008
    Denver, Colorado
    could be something as simple as your spark plugs.... and they are a hell of a lot cheaper than all of those other parts.
    Feb 19 2007
    2001 BMW 540i M-sport
    Charleston, SC
    possible a vacuum leak as well
    -Sami-
    Veteran Member Four Rings Audi Skate Snow's Avatar
    Mar 31 2004
    C300 Sport and tools
    CA
    wow this thread is all over the place...
    BetaAlphaTau member #1.5
    R.I.P B6 A4!!!!!! 12/03/2005 12.63@108... stock 1.8 motor W/ GTRS.
    B6 A4 Avant, 2.0 Liter, 3071, Maestro
    May 01 2008
    Las Vegas
    I was told NOT to upgrade the N75 cause its pointless. Also ill try unplugging the MAF tomorrow; but why does it show an ignition coils misfireing code if its the MAF? j/w.hopefully I unplug the right one. If it was spark plugs wouldnt the car not start right? or am i just a nub lol.
    I told the dealership to check for vaccum leaks but I dont think they did. I hear this big whistling noise that didnt used to be there..its def. not the turbo spoolin, but its basically only when the turbo spools so i think its a leak too..anyone know Johnathon Massey? thats who I bought the car from lives in florida. he gave me and f'd up car..I wanna get this crap fixed so I can start modding...
