Results 1 to 11 of 11
Thread: a-box m-box
    Jan 13 2008
    canada
    a-box m-box
    i know that must already be discussed but....
    I can have a deal for a A-box giac! is-it possible to re-code the cluster on a 2001.the giac have allready a maf conversion to hitachi.Do it need an other flash??or i should wait to find a m-boxflashed
    Jan 13 2008
    canada
    Re: a-box m-box
    ??????TTT
    Senior Member Two Rings nocturnals4's Avatar
    Dec 10 2007
    '00 S4, '94 Z28
    P-dena,Maryland
    Re: a-box m-box
    I think something is lost in translation bro...I dont understand the question. Hopefully someone can help you out
    Senior Member Three Rings AK1RA07's Avatar
    Dec 07 2007
    2001 S4, 1992 Miata, 1993 RX-7
    DFW
    Re: a-box m-box
    http://s4wiki.com/wiki/Cluster_recode
    I might have a GIAC M-box for sale soon if you wanna wait like a month.
    Veteran Member Three Rings Unispeed's Avatar
    Feb 22 2007
    Earth
    Re: a-box m-box
    IF you go over to an A box ecu you have to find a bosch MAF sensor too....
    2015 Audi A4 2.0TFSI (GEN 3 engine) with DL501 transmission (GEN 2 tran.)
    (B9 A4 engine mated to an S4 transmission in a B8.5 chassis. )
    2000 S4 6spd stg 2+ (gone but not forgotten)
    Jan 13 2008
    canada
    Re: a-box m-box
    i just want to know if i have an a-box giac,will it work in my 2001.5 s4???
    Dec 07 2007
    DFW
    Re: a-box m-box
    Quote Originally Posted by smooths4 View Post
    If you put an A box in your car you should have:
    1) a Bosch MAF
    2) a 6spd transmission
    Otherwise you need a different MAF / Recode the cluster
    Jan 13 2008
    canada
    Re: a-box m-box
    i know that.the a-box have a maf conversion for hitachi
    but i have the esp and abs cel
    Veteran Member Three Rings VR4-S4's Avatar
    Jan 24 2008
    2013 S6, 2000 S4
    Columbus, Ohio
    Re: a-box m-box
    keep the m-box
    B5 S4 - PJK04's Vast E85 Tuned
    452AWHP, 475AWTQ
    C7 S6 - RS7 Turbos Vast Tuned
    B8.5 A5 - GIAC Stage 1
    B8 A4 - Stock
    Feb 22 2007
    Earth
    Re: a-box m-box
    I just went from an A box to an M box myself. Why would you wanna downgrade? You should keep the M box.... As a side point, is your M box stock? I have an ABT/AMS M box ecu (almost as powerful as giac but with the smoothness of MTM). Would you be willing to do a trade plus $200? PM me if you are interested.
    Active Member Four Rings DxC's Avatar
    Nov 16 2006
    Boston
    Re: a-box m-box
    why is it an upgrade/downgrade to go from abox to mbox? i dont understand this perception. is it because the hitachi sensor is less prone to failure than the bosch? i just dont see the reason.
    while the map locations for a box and m box are different, the maps themselves are the same. most tuners tune to mbox just to keep things standardized
    FYI you can change any ecu to any box ... the information is stored in the eeprom.
    what you are talking about is changing the car to work with the box that you get... which i guess is doable too.
    THE MORE YOU KNOW.
    1999 Black A4 Avant
    2000 Nogaro S4 Stage 3
    2001 Nogaro S4 Stage 3
    2000 Black S4 - under construction Stage 5?
    2001.5 Santorin S4 Stage 3
    2001 Black S4 - parting out/scrap
    2001 Black Burnt S4 - shell gone, drivetrain remains
