Results 1 to 22 of 22
    Registered Member Two Rings
    Aug 13 2008
    Maple ON
    Angry Winter is here and my heating isn't HOT!!
    My heater was blowing cold air so I checked the coolent and sure enough it was low. I topped it of and the heater got a little hotter but only when I am driving. When I stop and a red light it starts getting cold again.
    Any thoughts of what my problem could be? It is a 01 B5 2.8.
    Any help would be greatly appreciated!!
    Thanks
    Veteran Member Three Rings s42k5b's Avatar
    May 31 2008
    New York
    Re: Winter is here and my heating isn't HOT!!
    I am going through the same problem in my b5 s4...i had no heat at all even when driving, and my car was running cold when i would get on the highway. So i replaced the tstat hoping it would solve my heating issue and it did somewhat. Now my heat works when im driving but gets colder when i come to a stop.
    00' Cactus, GIAC,H&R coilovers,original K03's for the time being..
    May 31 2008
    New York
    I guess we will both be having to replace our heater cores soon
    Aug 13 2008
    Maple ON
    I hope it's not the heatercore... Those are pricey!
    Is there anything else it could be?
    May 31 2008
    New York
    Well its not even the price, its where the heater core is located which is in the dashboard whoch is a big PITA to remove...very time consuming.
    May 31 2008
    New York
    i have no idea what else it could be..I have a very good tuner/mechanic who just works on b5 s4's mostly and he said he has never run into anything like this. The next thing i might do before the heatcore is replace my water pump.
    May 31 2008
    New York
    if you fix the problem please keep me posted as I will do the same for you
    Veteran Member Four Rings GetBoosted84's Avatar
    Apr 10 2007
    01 Audi A4 1.8T Quattro / 88 Mazda RX-7 GXL
    Eastern PA
    2001's have an issue with providing A/C or heat when the car is not moving. Poopie, Bassed, and myself all have 2001s and we all have that issue.
    As far as no heat while you are moving, that's a different story. What does your temp gauge get up to after the car is warmed up? Does it hit half-way in the gauge?
    Senior Member Two Rings deux321's Avatar
    Oct 21 2004
    2001 a4 1.8tqms
    central cali
    damn!!!!!
    haveing the same problem here too. cold all the time......
    subscribed.
    May 31 2008
    New York
    Quote Originally Posted by deux321 View Post
    damn!!!!!
    subscribed.
    how are your coolant temps?
    Veteran Member Four Rings FLACO X3's Avatar
    Jun 05 2008
    B5S4, B7A4
    Thornton & Elbert County, CO
    same problem. took it to a shop and it is is the flapper motor if i remember right. the thing that switches between hot and cold air. at least my heated seats work.
    2000 S4
    2008 A4 2.0TQ
    Aug 13 2008
    Maple ON
    Ok after doing some research and asking around I think its one of these two problems.... Either its the thermostat which needs replacing or the heatercore and or waterpump.
    I am due for a timing belt change soon in which I will change the water pump and probably change the thermostat too because I think there close together.
    Any thoughts?
    Veteran Member Three Rings kevin12's Avatar
    Jun 20 2007
    01.5 A4 1.8TQM
    South Jersey
    01 as well and I also have no heat when coming to a stop, driving however is fine.
    It must be something with the 01's like GetBoosted84 said because my 99.5 never had a problem.
    Current:
    17 Ibis White A3 2.0TQ S-Line
    01.5 Santorin Blue A4 1.8TQ 5-Speed
    Uni 1+, XS Power Exhaust, ST Coilovers, Forge DV
    99.5 Laser Red A4 2.8Q Tip Totaled RIP
    01.5 Casa White A4 1.8TQ Tip Current Parts Car
    08 Ibis White A4 2.0TQ Tip S-Line
    Active Member Two Rings redsky's Avatar
    Jun 26 2008
    1.8t Avant (AEB) !!!
    Florida
    I know a master tech at a VW/Audi dealership and he says those did have a problem with heater cores clogging up.
    1) Invest you must
    2) Time is your friend
    3) Impulse is your enemy
    4) Basic arithmetic works
    5) Stick to simplicity
    6) Stay on the course
    Veteran Member Four Rings CaSp3r9's Avatar
    Nov 30 2005
    Tools and toys
    Los Angeles, CA
    Replace the thermostat first because it's cheap (no more than $20) and relatively easy. If that doesn't work then you'll have to replace your heater core. Heater cores aren't incredibly expensive either, you just get screwed over on the labor to replace. I replaced the core in my friends A4 and it's not incredibly difficult just very time consuming but well worth the money you save.
    As for having warm air while driving and cold when stopped, IIRC that is related to the flap motor failing. If you have access to a VAG-COM, it'll tell you if that is the problem. If nothing shows up, chances are it's your heater core.
    1998.5 A4 1.8tqms, Sold
    2006 A4 2.0tqm
    I have a VAG-COM if anyone in the Santa Monica area needs it.
    Veteran Member Four Rings geeky's Avatar
    Nov 02 2008
    Boulder & Seattle
    has anyone tried doing a full coolant system flush with new 50/50 G12 mix?
    thats what i did and replaced my tstat/CTS in my 97 and havent had any problems since.
    1989 Nissan 300ZX
    Lemons Race Car
    1999 Porsche 911 Carrera
    1-Off Widebody | LS1 Swap | AST 5200 2-way Remote Coilovers | blah blah blah
    2000 Mercedes Benz C230K
    The Daily | "VIP Build"
    2000 Audi A4 1.8T
    The New Track Build
    2006 Porsche 911 Carrera S
    LN Engineering 3.8L | H&R Suspension | IPD Intake
    Aug 13 2008
    Maple ON
    Quote Originally Posted by geeky View Post
    Before doing this you had the same problem, no heat at idle but heat when in drive?
    Nov 02 2008
    Boulder & Seattle
    Quote Originally Posted by datacrime View Post
    my heat was ERRATIC. It be jumping around between no heat to middle of the gauge. It would fluctuate in heat when just at a red light and idling. Increase to about 1/4 on the gauge between 1-3 gear and then once in 4/5 (or highway driving) the temp gauge would drop all the way to the bottom again.
    but i did my tbelt with a friend on Wednesday and did a waterpump, tstat, CTS, and coolant flush and its been fine since. Car warms up to half way within 5mins of starting the car and then doesnt fluctuate at all. This is a A4 1.8TQM btw.
    1989 Nissan 300ZX
    Lemons Race Car
    2000 Audi A4 1.8T
    The New Track Build
    Account Terminated Four Rings
    Jan 09 2008
    B5 A4 Quattro 4,2L V8 6 Speed
    United Kingdom
    My 12V B5 quattro sport has the same issue - very cold air coming through.
    My car has no aircon.
    My gauge shows a regular 89 degree (halfway) driving or stationary, so definitely not the stat. A weak stat will allow the car to warm up, and blow warm air, however once doing a constant speed, will over cool, and the temp will gradually drop to cool / cold.
    Looking forward to pulling my dash to replace the heater core.
    Registered Member Two Rings Gibbs's Avatar
    Jan 10 2008
    Ireland
    i have replaced mt tstat, checked the flaps and done the aircon checks with vagcom and on my lcd display, still no hot air at any stage so looks like its gonna be a heater core this weekend :(
    in the mean time i picked up a 12V in car heater/fan thing, does the job ok but not great.
    Siena: how much is a core?
    Jan 09 2008
    United Kingdom
    @ Gibbs: I take it your car has climate?
    £118 delivered to your door.
    Veteran Member One Ring CthulhuAudi's Avatar
    Jan 07 2005
    98 2.8 tip stock
    Aurora, Illinois
    you might want to try a reverse flush of your coolant sys. before ripping out your heater core.
