Results 1 to 7 of 7
    Mar 19 2007
    new york
    putting my rings on the back again need help
    what kind of adhesive should i use?
    Veteran Member Four Rings ConroeS4's Avatar
    Oct 27 2008
    Montgomery TX
    Re: putting my rings on the back again need help
    I used emblem adhesive.
    Can be bought at autozone for $4
    2001.5 Audi S4 2.7T 6spd Santorin Avant
    Stage 2+
    ABT tuning, Milltek exhaust, SSAC downpipes, JHM short shifter, RS4 grill, All silicone hoses, Michelin Pilot Sport A/S Plus's, 034 street motor and snub mounts, Darintake, 12" Alpine Type R
    www.TexasAudiGroup.com
    Aug 26 2005
    3M double sided tape works good too.
    Registered Member Two Rings
    Dec 04 2008
    2002 A4 1.8T
    How difficult was it to take the back rings off? I hear using a hairdryer for heat helps?
    -Ball
    02 A4 1.8t
    15% all around, blackout grill.
    Veteran Member Four Rings OneBadAudi's Avatar
    Feb 25 2008
    02 A4 Quattro, 09 Yami YZ250f
    Cape May, NJ
    ^^ i used a heat gun and 10lb test fishing line, heated up the glue then went in between with the fishing line, pops right off..
    02 A4 Quattro stage 1+ (Giac Tuned)
    Siemens 380 injectors
    APR R1 DV
    K&N Air Filter
    5% tint
    STACKS boost gauge W/ Podi Column Mount
    Lip Spoiler
    Complete JL Audio sound system
    Aug 26 2005
    Fishing line lubricated with WD-40 works well also and avoids the chance of overheating the badge or the paint.
    Veteran Member Three Rings Scrwedtxboy31's Avatar
    Oct 19 2008
    2004 A4 1.8TQM (6sp)
    VA
    Quote Originally Posted by mwhockeyplaya22 View Post
    what Kind Of Adhesive Should I Use?
    How Did This Work Out For You?
