Results 1 to 2 of 2
    Veteran Member Four Rings jackyaudi's Avatar
    Jun 26 2007
    '02 A4 1.8TQS
    Montreal
    Noticed 2 issues @ 6200 RPM
    Car: Automatic, 1.8T Quattro, 2002, 91 octane, 1/4 of the gas tank left.
    1) I was doing some spirited drives today and I noticed at 6200 RPM I hear a noise, its maybe a slight knocking, or some kind of "kreeek" noise that lasted for about a second or 2. It did not happen at all anywhere between 2000 to 6000 RPM.
    2) Also, when the car goes to say 5500 RPM and shift gears and goes down to say 4000RPM, I feel like the car acts similarly when a manual car shifts at high speed, you feel this sudden "shifting move", as if the car is forced to stop for a second.. This only happens when am at 4500+ RPM. Not sure if its engine mounts or transmission. I visually checked the engine mounts, they seem ok, no leaks around them.
    What do you guys think?
    For your OEM HID D1S/D2S/D3S and HID conversion [Headlights/Foglights], and Interior/Exterior LED needs, send me a PM.
    Stuff F.S: http://www.audizine.com/classifieds/...4-parts&cat=21
    Veteran Member Four Rings A4 Moda's Avatar
    Jun 11 2005
    2003 Audi A4 1.8TFSM
    SoCAL- City of Industry
    Re: Noticed 2 issues @ 6200 RPM
    sounds like engine knock, pre-ignition, or detonation.
    Might want to turn down the timing a tad.
    Eurocode TINY Turbo GT71R Eliminator:: REVO Tuning::
    2003 1.8T
    Eliminator||Carbonio V2||ATP EXhaust Manifold ||Neuspeed TIP (Eurocode)||JOE P MBC @ 22PSI B9- Timing 5||Custom 3" Exhaust||Mangaflow Mufflers|| Revo||Reiger||Boser hood||S4 Bixenon Ecodes||LED Tails||Eibach Coilovers||
