Results 1 to 4 of 4
    Veteran Member Four Rings ConroeS4's Avatar
    Oct 27 2008
    Montgomery TX
    tinting tails with niteshade
    What are the ptopoer procedures for tinting them?
    What tools will I need? Is there anything else I could use other than vht niteshades?
    Thanks
    Cameron
    2001.5 Audi S4 2.7T 6spd Santorin Avant
    Stage 2+
    ABT tuning, Milltek exhaust, SSAC downpipes, JHM short shifter, RS4 grill, All silicone hoses, Michelin Pilot Sport A/S Plus's, 034 street motor and snub mounts, Darintake, 12" Alpine Type R
    www.TexasAudiGroup.com
    Veteran Member Four Rings vdubstreets's Avatar
    Feb 20 2007
    02 a4, 97 Gti, 90 wrangler
    ct
    Re: tinting tails with niteshade
    screw driver to take out the tail light.
    clean the tail light (tape it up if you want).
    Spray light coats until your satisfied with the darkness.
    If you want a shinier finish apply lots of thin coats of clear.
    you can go to a hobby shop and pick up some spray on tint that's what i used.
    Veteran Member Four Rings JumboBlack1.8's Avatar
    Sep 16 2006
    '98 528i
    Boston/West Hartford, CT
    Its best to get some plastic adhesion promoter before you spray on the tint.....this will help prevent the spray-on tint from running if you happen to over spray
    2000 Audi B5 S6 ** 4.2L 40v S6 6spd - http://www.audizine.com/forum/showth...n-s6-4-2L-swap
    Veteran Member Four Rings 04QuattroTurbo's Avatar
    Jun 15 2008
    Fairfield, CA
    Quote Originally Posted by JumboBlack1.8 View Post
    Absolutely! The plastic Adhesion spray will allow for a even spray and prevent cracking, etc. You should also hit it with a couple of coats of clear. Do not put on too many coats of base Nightshade, it may get too dark for you.
    I did mine with VHT Nightshades:
    If you search, I posted the procedures, step by step.
    More Pics:
    Before:
    After:
    2004 (B6) Audi A4 Quattro 1.8L Turbo 6-Spd Man
    Premium Pkg, Cold Weather Pkg, Ultra Sport Pkg, Lighting Pkg, Sirius Satellite. Dolphin Grey
    APR Stage I, K&N 33-2209 Drop-in filter, Apr Snub mount, RS4 pedals
    VIN Decoded: http://www.motoverse.com/tools/vinDe...LC68E84A219972
    USP Member 110
    WANTED: Roof Spoiler, PM me with Offers.
