Results 1 to 28 of 28
    Apr 15 2007
    09 Black A5
    Indianapolis, IN
    A4 Engine Noisy & Horrible Vibration
    For a couple of months now, I have noticed that my 2005.5 A4 has been loud at idle and while driving. In addition, I can sit a glass of water on my dash and it is vibrating like an earthquake just hit in Cali. I brought it into the dealership and they said it was normal. I opened my hood and took my turbo cover off and it sounded like a diesel engine under the hood. I know Audi's should not sound like this. I have about 52K miles on my vehicle. Does anyone know what the cause of this problem may be? Bad coil pack? Something to do with the exhaust? Something rubbing in the engine somewhere? Any help would be excellent. I plan on going back to the dealership tonight and have them take another look at it...
    Active Member Two Rings krazykorean's Avatar
    Nov 03 2008
    2007 Audi A4
    Phoenix
    Re: A4 Engine Noisy & Horrible Vibration
    the only thing i can think of the bad vibration at idle is bad motor mounts. And ive also heard that some cars sound loud from under the hood but im not sure about that part.
    ~Jihan
    Apr 15 2007
    09 Black A5
    Indianapolis, IN
    Anyone else have any ideas or suggestions I can tell the dealer?
    Veteran Member Four Rings supamannn99's Avatar
    Nov 15 2007
    Orange County, SoCal
    its probably the motor mounts causing vibrations
    Veteran Member Four Rings p1nk50ck's Avatar
    Sep 18 2008
    06 Audi A4 S-Line
    Arlington, VA
    see if they have any other b7's in the lot, and put them up side by side. one should be noisy and have lots of vibrations, one should not. let them know that it wasn't like this a couple of months ago.
    Veteran Member Three Rings TrboPowr's Avatar
    Nov 23 2005
    2007 A4 S-line Turbo, 2007 A6 Avant, 2010 Porsche Cayenne GTS
    Washington DC
    motor mounts... and the diesel engine sound is normal actually because of FSI making it sound like a diesel at idle.
    2007 RAI B7 BORG WARNER EFR
    Deval│Vorsteiner│Bilstein│Brembo│Oettinger│Borg Warner
    Mods = Bitch slap to my bank account
    Apr 15 2007
    09 Black A5
    Indianapolis, IN
    It is much louder than a couple of months ago. When I first purchased the car, you could barely tell it was on. Now, I can go inside my house and hear it outside in the driveway. I cannot imagine that that is "normal" for a $36K vehicle.
    Nov 15 2007
    then there's something wrong. my car isn't even that loud and i have an exhaust.
    Senior Member Two Rings windextor's Avatar
    Jan 20 2007
    both of mine have been pretty loud since day one...diesel sounds about right for the noise comparison...never really noticed anything above normal vibrations though
    10 A4 2.0T 6MT quattro Ibis White Sport - current
    06 A4 2.0T 6MT quattro Quartz Grey Metallic S-Line - gone
    07 A4 2.0T 6MT quattro Ibis White S-Line Titanium - gone
    04 A4 1.8T 6MT quattro Dolphin Grey USP - gone
    Veteran Member Four Rings RedS-line's Avatar
    Mar 19 2008
    2019 S5, 1990 944 S2
    welcome to the 2.0t engine. its noisy, vibrating, and and unrefined. but man does it put down torque when you get into it! some cars are worse than others. maybe have a scheduled service done early?
    2019 S5 BO.SS
    1990 944S2 Cabriolet
    2009 R8 6 Volt :)
    Veteran Member Four Rings Slo.Mo.Shun.'s Avatar
    Oct 14 2006
    MK6 Jetta
    South,FL
    Does it vibrate when you get on boost ?
    -Unitronics Stage 2+ ECU/TCU tune.
    -EI AL CAI.
    -Driver Mod.
    DUH! an Audi
    los angeles, CA
    on 05.5-06 the sound of a disel engine is quite normal. My neighbor who works on old Benz was shocked to hear it sound like that, needless to say after taking car to the dealer it still made that sound.
    If it's making a loud sound while driving, than that is another issue. It's hard to conclude anything without hearing in person, I would also imagine if something was wrong dealer would want to change something to make money.
    Post a sound clip.
    -randy
    Nov 26 2007
    So someone else is finally noticing how messed up this is for Audi keep us posted on what stupid reason the dealer is gonna give you.
    Veteran Member Three Rings snosk8tr123's Avatar
    Jan 08 2007
    2007 Audi A4 2.0t
    Orange County
    mine vibrates a lot too. I noticed that it happens when the ac is on and im in drive, but stopped
    s-line titanium + plate filler + ecs smoked sidemarkers + GIAC 91 octane + Koni Coilovers + e-code test pipe + DMH electronic exhaust cutout + forge dv + bov spacer + tint + LED city light + LED license plate bulb + Yellow PIAA fogs + White Nokya Headlights + European rewiring of lights + Clear corner and blacked out housing + Red LED door lights and foot well lights + debadged + Black audi rings + Light smoke taillights + VMR vent boost gauge + DOPE sticker (+50 whp)
    Senior Member Two Rings A4CE1's Avatar
    Feb 10 2008
    06 A4 2.0, 03 Wrangler, 96 XJ
    Westchester, NY
    Quote Originally Posted by HID View Post
    what does that mean? mine is doing that i was about to post and ask what could be going on... its pretty bad
    not to thread jack tho...
    VW Touareg V10 TDI. Don't mess.
    Past: Stg. 2+ B7 2.0T, B6 A4 1.8T, Allroad 2.7T 6spd (<-monster), Chevys, Jeeps, and a Nissan.
    Understeer is when you hit the wall with the front of the car and oversteer is when you hit the wall with the rear of the car. Horsepower is how fast you hit the wall, torque is how far you take the wall with you, Body kits and decals are how much of a mess you leave on the wall.
    Apr 15 2007
    09 Black A5
    Indianapolis, IN
    It vibrates worse when it is in park or I am not moving. When I am driving I don't really notice the vibrations...
    Established Member Two Rings Who Needs 8's Avatar
    Aug 01 2008
    2006 A4, 1989 Turbo Trans Am
    Dallas, TX
    Loud "clicking" could also be a leak or even a hair line fracture in the exhaust manifold/turbo exhaust housing.
    Nov 26 2007
    We need to file a complaint with Audi north America and not through dealerships as this is totally unacceptable we all need to complain colaboratively because the newer A4 does not have this problem.
    Apr 15 2007
    09 Black A5
    Indianapolis, IN
    I have attached a clip of my engine. Mind you, this was at about 6 inches away from the engine, but you will get an idea of the pitch and sound it is making. The clip is from starting the engine and running for about 20 seconds.
    Download sound file here: A4 Bad Sounding Engine
    Sep 02 2008
    Boston, MA, USA
    Quote Originally Posted by 2871mds View Post
    Oh jesus, here we go. Its normal and thats all there is to it. Its a 4 cylinder and thats how 4 cylinders are. That's why they offer the V6, and thats probably why BMW and Mercedes don't even offer a 4 cylinder (here in the US anyway). It's also Audi's first production FSI engine, and the new A4 is more refined because its, well, newer.
    Sep 02 2008
    Boston, MA, USA
    Quote Originally Posted by BLarche View Post
    If that's with the hood open, i don't think that sounds very bad. Its a little louder than mine, but my VR6 sounded about the same.
    Veteran Member Four Rings a4dc89's Avatar
    Nov 07 2007
    Land Rover Disco I
    Washington DC
    Its the FSI and get used to it thats the way it is for the earlier years i believe. The later years have a slightly different fueling system and as a result it sounds a bit different and has different characteristics.
    2006 A4 B7 2.0TQ Dolphin Gray Metallic 6MT
    REVO Stage II, 034 HFC, AEM turbo inlet/intake, OEM Piston DV, BSH PCV Fix, HID Fogs/Fog Mod, AWE Boost Gauge, Debadge
    All go no show
    Senior Member Three Rings rayiish's Avatar
    Feb 03 2008
    Brooklyn, NY
    05.5-06 is louder than 07-08 so yea.. get used to it.
    Ray
    2006 Audi 2.0T Quattro w/ Tiptronic -Dolphin gray | APR 93 | RS4 Rearsway bar | Tinted head lights/tail lights/side reflectors | Bulbs changed | Clear Corner
    Jan 08 2008
    i had the excessive vibrations at idle on my car too, and i took it in and some valve/flap thing was broken/stuck so they had to replace it. It was still under warranty (40k) and now it's all better.
    Apr 15 2007
    09 Black A5
    Indianapolis, IN
    Okay, so you all say this is normal? But why in the hell does my steering wheel vibrate like it is going to fall off? Is this normal too? If it is, I will never buy another Audi again.
    Veteran Member Three Rings Bryan's Avatar
    Mar 20 2007
    Vancouver
    Sometimes when car is at idle my steering wheel vibrate like hell... but not all the time, I think its normal for our 05.5 A4, u need to used to it !!! =P
    Bryan K
    06 B7 A4 - Slightly Moded.
    09 8P A3 - Slightly Moded.
    10 B8 A5 - Slightly Moded.
    11 B8 S4 - Milltek exhaust, H&R, BFI spacers.
    Jan 08 2007
    2007 Audi A4 2.0t
    Orange County
    Dude I feel what you're saying. But i have several friends with a4's and theirs isn't like mine. It is most likely something wrong that they just dont know what. Every other audi is way more solid though. POS 2 liter
    Active Member Two Rings sysadlight's Avatar
    Nov 27 2008
    NH
    Mine sounds the same as your clip. Everyone that hears it remarks on it. Sounds just like a damn noisy diesel. I have nothing to compare it to, but plan to bring to dealer at some point to at least try and hear another one and see if they all sound the same.
