Results 1 to 18 of 18
Thread: Whinning noise
    Senior Member Three Rings G-Bus's Avatar
    Aug 25 2008
    Montreal, Canada
    Whinning noise
    I get this whinning nosie when I drive in my car. If I accelerate hard, it doesnt do it, lets say from 1st gear. If i start slowly I get this whinning. Its independant from the engine, or from the tranny in the way that I could be in gear or not and it doesnt affect it.
    What can it be?
    Veteran Member Four Rings aaaudiprotein's Avatar
    Apr 17 2007
    2003 RS6
    Chicago Burbsss
    Re: Whinning noise
    Where is it coming from?
    Common "whinning noise" from a rear pasenger side is bad fuel filter/pump
    BLACKHAWKS 2010, 2013 and 2015 STANLEY CUP CHAMPIONS
    Windows 7 WAS MY IDEA
    Registered User Four Rings winston@podi.ca's Avatar
    Jun 11 2005
    Pods, gauges and more pods
    Vancouver, BC
    Re: Whinning noise
    fuel pump or fuel filter
    Aug 25 2008
    Montreal, Canada
    Re: Whinning noise
    Its not constant and it's not coming from the back, its coming from the front. It really isnt constant.
    Veteran Member Four Rings Audized's Avatar
    Oct 22 2006
    Eh?
    Re: Whinning noise
    I have the same noise. It started a month ago. I have yet to find out what's wrong with my car. It happens in 1st and 2nd gears and sounds like it's from the engine bay.
    Veteran Member Three Rings fitch303's Avatar
    Jan 03 2008
    Columbus, Ohio
    Re: Whinning noise
    I have this same issue, at first I thought my turbo was going out but that made no sense. If the noise is normal then great, if not something it broken and i'll just wait for the check engine light before I start to give a shit.
    Apr 17 2007
    2003 RS6
    Chicago Burbsss
    Re: Whinning noise
    Do u have a cone filter?
    Aug 25 2008
    Montreal, Canada
    Re: Whinning noise
    No cone filter and as autumn and fitch303 said, it's also only in first and second even tough it doesn't seem like it's related to the tranny since I could be in gear or not and it does it anyway, I think it has to do with speed.
    Veteran Member Four Rings BOPOH's Avatar
    Oct 08 2007
    Columbus, OH
    Re: Whinning noise
    i had samething and you'll never believe what it was. my power steering was empty, i filled it up and its all good now
    Senior Member Two Rings MAJI's Avatar
    Dec 06 2007
    B6 1.8T Quattro
    Santa Ana
    Re: Whinning noise
    is it a whining/grinding noise when your in gear that mean your gear is chipped.. as in like a piece cracked off.. if it is a higher pitch whining noise your turbo might be going out.. check for leaks...
    I LOVE CARS
    Present Cars: Audi B7, 2007 Mustang GT - Buliding in progress. Supercharger kit, 1993 Off-road Range Rover, 2004 Toyota Sequoia
    Past Cars:
    Audi B6, Lexus SC400. 1967 Mustang, 1997 Honda Prelude, 2002 Dodge Ram
    Aug 25 2008
    Montreal, Canada
    Re: Whinning noise
    No its independent. If I put it in gear or not, it doesn't change anything. I don't know if its turbo or not, I'm not chipped and the car doesnt drink oil.
    Veteran Member Four Rings vdubstreets's Avatar
    Feb 20 2007
    02 a4, 97 Gti, 90 wrangler
    ct
    Re: Whinning noise
    This is kind of dangerous, but you say its independent of the motor what if you find a hill with no one around and you coast down it with the motor off, would this noise happen? If it does its a Drive-train, suspension issue and you can lead out the motor all together and if its in neutral when you are coasting is probably not a tranny issues as well. This maybe a stupid question but you have to ask does it sound like a wind noise at all like bad weather stripping? is it in conjunction to the speed your going does it get louder?
    Jan 03 2008
    Columbus, Ohio
    Re: Whinning noise
    for me it happens in reverse and first gear, the noise last for a few seconds and the pitch gets higher but not at the same rate my rpms go up. Also after the car has been sitting for awhile and I start to drive in first gear I hear the faint and sudden grinding noise after the first foot or so of travel.
    Aug 25 2008
    Montreal, Canada
    Re: Whinning noise
    Quote Originally Posted by fitch303 View Post
    Mine is independent from the tranny but reading your message, I remember that I have one tranny flange seal thats leaking so I will change that as well as my tranny and diff oil next week on thursday. I spoke to some shops and they told me to not worry too much about it. If it doesnt amplify or anything nor check engines.
    Well see after I change my tranny and diff oil.
    Jan 03 2008
    Columbus, Ohio
    Re: Whinning noise
    Quote Originally Posted by G-Bus View Post
    Ahh yes. When I took my a4 in for an oil change the mechanic came out and said I had a front seal leak on the tranny, he did not go into detail. I plan on changing this myself because the stealership wanted 1100 to fix it plus another 700 to change my thermostat. I changed the thermostat myself. Which seal are you replacing and what is the part number?
    Oct 08 2007
    Columbus, OH
    Re: Whinning noise
    did i miss something or NOBODY mentioned BELTS? you know they spin when your car is running, and when you start moving they can make noises. What about weather, if its cold or rainy or whatever? my buddy's jetta make all kinda noises when he broke his skid plate and water gets on belts. check that
    Jan 03 2008
    Columbus, Ohio
    Re: Whinning noise
    belts turn at the same rate as the engine, and the sound is independent of the engine rev.
    Aug 25 2008
    Montreal, Canada
    Re: Whinning noise
    I tried it with the car turned off and it still did it...! But it only did it 15 minutes after I started the car after it got really worm it stopped. I called a local shop and they said that sometimes its normal because it kinda got cold here.
    It's a flange seal, the one that the axle attaches to. It costs 20$ and is about 1 hour of labour.
    I got quoted 250$ for this;
    -Motor oil change
    -Tranny oil flush and flange seal replacement
    -Rear diff. oil flush
    Price includes labour and oil.
