Results 1 to 3 of 3
    Veteran Member Four Rings BlackB6's Avatar
    Apr 03 2008
    Pennsylvania
    Anyone with 19x8 with 30mm offset?
    I'm looking at RS6 Replica rims and I see that the size is 19x8 with a 30mm offset. How will this look? I definitely don't want my rims sticking out of the fender wells. Anyone with this setup please post up some pics. Thanks guys.
    Active Member Two Rings karlitooo's Avatar
    Nov 14 2008
    Audi A4 1.9 TDi S-line (187Hp)
    Belgium
    Re: Anyone with 19x8 with 30mm offset?
    Quote Originally Posted by BlackB6 View Post
    If you look my wheels ,they are in 8,5/19 with 43 mm offset.
    As we know 1" = 2,56cm
    1/2":1,28cm
    43mm - 12,8mm = Offset 30mm
    The wheels look like a 8/19 with offset 30 ;-)
    Http://German-kar-litooo.skyblog.com
    Drive 2 low 4 the show...
    Forum Moderator Four Rings actlsub9's Avatar
    Jun 13 2005
    Audi
    Quote Originally Posted by karlitooo View Post
    1/2":1,28cm
    If your wheels are 19x8.5 et43 then they stick out the same as 19x8 et36. Check your math.
    Greg - Moderator
    WWW.ACTLSUB9.COM
