I owned a K04 B5 and a GTRS B6, The way i look at it the B5 should have had that turbo stock, and the B6 should have the GTRS stock, but that is not the Case.
the B5 in quattro and a 2000 or 2001 is a nice compromise, as they are getting cheap. But if you have any ambition of larger than stock turbos i would reccomend the 1999.5 because it has a better flowing head, larger Intake Manfold, Drive by Cable throttle (easier to modify, tune, piggyback standalone etc.) and has the more current head light and taillights.
but if you want to have a good power and reliablity go with the V6 in any year or body style.
You said you already have a High Power Front Drive turbo, if you think about hooking up similar power with AWD you will be addicted and not drive the FWD. just food for thought.
A 2002 B6 with 1.8T quattro is less than ten grand then spend 3 grand on a gtrs, and you should be happy for a while.
