Results 1 to 22 of 22
    Veteran Member Four Rings oc-drop's Avatar
    Nov 20 2005
    B7 A4, C5 A6, 79 Camaro
    Newport to Rancho Sta Marg
    No parking light with ecodes?
    I just got a set of A6 ecodes, and I am wondering if the corners not staying on is normal? They blink fine, but I'd like to utilize them as my parking lights along with the DRLs or when the headlight is on.
    Can anyone give me some advise?
    ~Rick .. currently driving a B7 3.2 S-Line 6MT Dolphin Grey | DTMish | EuroGEAR CF Hood | H&R | sick halogen Ecodes | AZ Plate frame
    is it 4:20 yet?
    Nov 20 2005
    Re: No parking light with ecodes?
    so far its looking like a no, especially since the bulb is single filament.
    I guess a lot of people like the "amber off" though ~ that seems risky
    is it 4:20 yet?
    Veteran Member Four Rings Silverstreak98's Avatar
    Dec 11 2006
    Minnesota
    Mine are dual filament and used to come on with the parking lights.
    I didn't like it so I put a small piece of ecletrical tape over one of the connections so I only comes on as a turn signal.
    ~Brian
    1998.5 A4 2.8QT
    Nov 20 2005
    Quote Originally Posted by Silverstreak98 View Post
    I read your posts in the B5 section I guess the A6 corners are different
    is it 4:20 yet?
    Nov 20 2005
    I'm going to try a Frankenstein experiment and see if I can get this to act how I want it to
    is it 4:20 yet?
    Jul 30 2008
    08 Passat 2.0t
    Near Mountain Creek
    Do the old (stock) bulb sockets fit into ecodes?
    If yes.... use that, and run a wire from the city light to the stock socket
    08 Passat wagon 2.0T 6MT (APR Stage I, DriverGear-Eibach springs, Bilstein Sport, Euro smoked tails, intake, ATE Premium One rotors, Hawk HPS, Tyrolsport Caliper Guide Bushings, other stuff)
    Previous Cars:
    02 Golf TDI 5MT (Chipped, Bosio PP764 nozzles, VNT-17, Shine Racing suspension, S3 strut brace, WRD rear strut brace)
    88.5 Camry V6 5MT
    84 Corolla 3AT (the FWD version, hand-me-down)
    Nov 20 2005
    It might work without re-wiring
    going to try it out tonight
    is it 4:20 yet?
    Mar 26 2005
    01 A4 1.8t avant; 04 B6 S4
    All over the Bay Area
    what bulb does the A6 use for corners?
    TEAM|AXION
    Nov 20 2005
    stock is 7528 dual filament
    the ecode one looks like 7506 but I'm not positive, it is however single filament, compared to the stock dual filament
    is it 4:20 yet?
    Mar 26 2005
    wierd..I just got myself a set of ecodes for my b5, and I had to reuse the oem US bulb holder/connector. the oem connector does not connect to the holder on the ecodes.
    TEAM|AXION
    Nov 20 2005
    I heard that with a little finesse that the us bulb holder fits ecodes (at least on a B5)
    I've yet to try it on my C5
    is it 4:20 yet?
    Nov 20 2005
    well the US corner socket fit, but didn't act right
    so I'm just going for it and installed them as is... and I'm surprisingly happy =)
    is it 4:20 yet?
    Mar 26 2005
    nice! I gotta learn how to hook up my city lights. how did you do it?
    TEAM|AXION
    Nov 20 2005
    they're stock on euro lights, so I didn't have to mod anything... plug & play for the A6 at least
    If anything I'd think you could just wire it to the corner lights
    is it 4:20 yet?
    Mar 26 2005
    Quote Originally Posted by oc-drop View Post
    I was afraid to see that answer haha. I hate dealign with anything electrical, especialyl on our cars :\ well..I'll try to make it work during thanksgiving break haha
    TEAM|AXION
    Registered Member Two Rings Fleet Admiral's Avatar
    Mar 12 2009
    A6 2.7 | ecodes | CH air comp|
    MI | umich.edu
    The parking lights are supposed to be that way for Europe, it's the law(and a better one) so people don't get confused. I also read that there is no law in the US that says you need amber parking lights on with headlights, they just do it for some reason.
    And if you notice, the euro cars have been importing them that way for years on some Merc, BMW, VW. My '02 Passat didn't have parking lights on with headlights. Mercs don't either. My VW just had city lights, and hence used a 2 position headlight switch. Either ON or OFF, no in between "parking light" setting, that for some stupid reason after '01 they disabled in favor of pumping lower wattage through your headlights, thus burning them out quicker. The city lights only came on with headlights after '01.
    The turn signal is for TURNING, not letting people see you. That's what the headlights are for. The only requirement is the illuminated side reflector. Some put it in the headlight, the smarter makers put it on the bumper so we can remove it or black it out because it's stupid. Europe doesn't need the damn things, but I guess US drivers have lower IQ to miss seeing a big object sideways in the road or driveway.
    You can't lose choosing me doll face. Every lotto ticket I scratch off is a winner, cuz I'M a winner
    Aug 26 2005
    Yeah, with the eCodes, the City Lights replace the "clearance" or front corner parking lights, and are powered by the same circuit. That way, the city lights are ON with the clearance (parking) lights, while the headlights are OFF. That is what the city lights are for, driving in the city with lots of bright street lights, when the main low beams are not needed.
    Mar 12 2009
    MI | umich.edu
    The city lights are so dim they're hardly noticeable in daytime which enforces the above post. They're not blindingly glaring like incompetent US automakers make them. But the way they're styled on the angular lens of the pre facelift A6 makes them look kick ass on side angles and approaching intersections makes other drivers notice the jewel effect as they pass you in the opposite direction.
    This doesn't apply much so to the newer round lens design of the Audi or others, it doesn't reflect as much.
    Aug 26 2005
    Specifically,
    http://www.audizine.com/forum/newrep...eply&p=3658010
    Feb 15 2008
    AWE powered B6 1.8T
    Severna Park, MD
    I know this is a slightly old thread, but seemed like a good place to ask. What is the bulb type for the LED city lights on B6 S4 Bi-Xenon ecodes?
    Mar 30 2008
    Narragansett, RI
    Hey...I am trying to bring my Audi A4 here to Germany....I need to make it so that the parking lights are off in the front headlights, when the headlights are on. Why the hell do they do this in the US? Retardedness. Oh well, so I need to get that done before I ship the car.
    Can an Audi dealer change this feature with a VAGCOM computer, or do I have to just wire it differently....Or can I just buy a different bulb with only one filament instead of two? But if I do this, will I get a "blown out" bulb signal on my dashboard???
    Thanks...
    Joey
    Aug 26 2005
    You need to install ecode headlight housings.^^
