Results 1 to 13 of 13
    Oct 29 2008
    02 a4 92 gvr4 03 r6
    car pulls to the right, even after alignment
    so my 02 1.8t quattro likes to pull to the right pretty hard even after an alignment. What types of things would cause this? ball joints and tie rod ends? the car itself rides smooth with no major clunks. Also, sometimes it will ride straight with out any problems and then other times you can feel the car just pull hard to the right.
    car has sport package too if that makes any difference... (guessing the only difference is springs/struts)
    any thoughts would be appreciated. thanks.
    Veteran Member Four Rings lookaught's Avatar
    Apr 20 2007
    2002 1.8t Avant GTRS, Aprilia SXV 550, BMW F800GS, Ram EcoDiesel, 1990 Bronco
    Lander, Wyoming
    Re: car pulls to the right, even after alignment
    Try driving in a really flat parking lot, it could just be the roads drainage slope.
    Also try rotating tires. Finally, just becuase it was aligned doesnt mean it was done well, ask for a printout of the specs if they still have it. If it doesnt track strait in a parking lot take it back and complain, I once had to do this three times after an alignment!
    Jon
    go > show
    Ich liebe mein Audi
    2002 GTRS Avant - Built with love, sweat, bloody knuckles, and pride.
    Oct 29 2008
    02 a4 92 gvr4 03 r6
    its def. not just the roads as i can feel the car actually pull to the right and i physically have to put pressure on the wheel to the left to keep going straight. this worries me because i dont want to eat up my new set of tires.
    Veteran Member Three Rings msharifi's Avatar
    Aug 13 2008
    Orange County Cali
    check the tire PSI to see if they are set correct. Best to check it is when the tires are cold. If one tire has less air it can pull and I seen it before on mine.
    Oct 29 2008
    02 a4 92 gvr4 03 r6
    Quote Originally Posted by msharifi View Post
    did that... all tires were within .5 psi of each other.
    Veteran Member Four Rings G Men 08's Avatar
    Feb 05 2008
    One trick pony at the time.
    Waterloo NY
    if its pulling that hard then you either have a worn suspension maybe ball joint or tie rod, or the alignment wasnt done correctly as stated
    B6 A4 3.0-sold
    C5 A6 4.2-sold
    C4 A6 2.8-sold
    B5 S4 A few mods-SOLD thankfully!!
    MKIV Golf TDI- SOLD MPG were amazing but other than that...
    C5 allroad 2.7 auto
    Veteran Member Three Rings cjonesgo's Avatar
    May 22 2007
    02 A4 Avant 1.8t qm, '74 Vespa
    oakland ca
    Does it do this on rolling or when brakes are applied. Either way, you may just need a brake job, or possibly even a caliper rebuild if seals are shot. If the brakes on the right side are dragging (not disengaging) then the car will pull to the right even if you are not pressing the pedal.
    put your car up and test wheels for resistance when spinning them by hand.
    [CENTER]02 A4 Avant 1.8tqm Dolphin Gray
    Blackout Grills | S4 Bi-Xenons | 3.0 Brakes | RS4 Rear Swaybar | Bilstein Sport Shocks
    K04 | REVO | TT225 Injectors | Apikol SMIC | 034 HFC |
    Oct 29 2008
    02 a4 92 gvr4 03 r6
    Quote Originally Posted by G Men 08 View Post
    i was guessing suspension component since sometimes its fine and other times i can really feel it pull, so something has to be on its way out.
    Veteran Member Four Rings coowhip's Avatar
    May 11 2008
    Columbus, OH
    is your brake grabbing on that side at all?
    Dec 06 2007
    it is called radial pull one of ur tires are pulling it to the right, rotate ur tires and see what happens if it lessens then u know the cause
    -Kirk
    BetaAlphaTau Member #58
    Oct 29 2008
    02 a4 92 gvr4 03 r6
    Quote Originally Posted by AudiA4Turbo22 View Post
    i am pretty sure you nailed it. The previous owner stretched the tires too. they are 225's on a 8.5" wide mandrus rim. I just put my winter rims on and it has not done it since.
    Dec 06 2007
    ^^had the same exact issue myself drove the car home from an alignment and the car pulled as bad as before i arrived.
    -Kirk
    Veteran Member Four Rings BOPOH's Avatar
    Oct 08 2007
    Columbus, OH
    my car is pooling to the right hard as well but i know that my CV boot is shot and its been that way for few month so im sure some dirt got into it
