Results 1 to 7 of 7
Thread: Clutches....
    Mar 07 2008
    93 Saab 900, XR650R,
    Clutches....
    I badly need a new clutch! So I was looking at the 034 240mm kit
    http://www.034motorsport.com/product...ducts_id=13298
    Will this hold up to a BT setup?
    Jul 07 2004
    630AWHP A4, Nissan Titan
    socal
    Re: Clutches....
    Spec also makes a 240mm kit that can be ordered in different stages. 034 is putting one of those on a B6 that is 2 liter/GT30r and will be running a stage 3+ clutch 240mm setup.
    Mar 07 2008
    Re: Clutches....
    F**k i was guna get the 240mm kit. i got a southbend stage 4 OFE with steel flywheel will i have problems????? as far as chatter and engagement?
    Feb 15 2008
    E46 323i 5-Sp
    616/MI
    Re: Clutches....
    034 claims it'll 400lb/ft of torque. My SPEC 228mm will hold 410lb/ft.
    Personally I'm really happy with my SPEC. I purchased the Stage 2+ w/ Steel 16lb FW.
    If/when I upgrade to a larger turbo and internals I'll probably go with the 3+ clutch/pressure plate OR the 240mm Stage 2 kit.
    I buy stuff from 034 and I'm very happy with their services, I won't talk you out of buying anything they sell (they sell SPEC too).
    Maybe just look into how big of a turbo you could even consider buying, and buy something that could hold that. When I bought mine, the biggest I thought I could want was a 2871, now I think I would go with a 3076 or an HTA if I went to a larger turbo.
    Mar 07 2008
    Re: Clutches....
    ok and with the 16lbs flywheels it drives fine? how is the engagement with the single mass?
    Feb 15 2008
    E46 323i 5-Sp
    616/MI
    Re: Clutches....
    Drives great with the 16lb. Considering the turbo size, torque curve comes in smooth, and driveability is great.
    Like any 4cyl though it'll chug/buck/generally get pissed off if you load it in a high gear below 1500rpm. Other than that I actually prefer the single mass to any dual mass I've driven.
    Mar 07 2008
    Re: Clutches....
    alright that's good to hear thanks
