Results 1 to 12 of 12
    Jul 31 2008
    04 Audi 1.8T
    Markham Ontario
    Fuel Filter Cost/Repair
    Hey guys,
    I have a B6 A4 1.8T. How much should a fuel filter replacement cost? I know the filter is around $20-25 bucks. Two shops have quoted me $200+
    They both said it would take about 2 hours to replace. Isn't this an in-line filter. Unscrew two lines remove, replace and screw the lines back on? This shouldn't take 2 hours.
    A buddy of mine has a 330ci and he said it his shop 20 minutes. Unfortunately that shop is downtown TO. I live up in Markham. Any idea where I could go up here?
    Thanks
    Sam
    Veteran Member Four Rings hoganalley's Avatar
    Feb 23 2007
    Burlington
    Re: Fuel Filter Cost/Repair
    depending on the position of the filter, I could see $200. In the B5's it's "suggested" you drop the fuel tank, remove the rusted bolt, pull down the filter and swap it. There is a plastic strap holding the filter onto the gas tank and it's wedged between the tank and the underbody panels. I just changed mine a few months ago and it was a pain, but doable.
    What does Independant Tuning quote you? They're usually spot on with those things......
    14 A4 allroad - stock
    05 allroad 2.7T Stock
    Veteran Member Three Rings orangelmo's Avatar
    Jul 05 2007
    Stouffville
    It definitely will not take 2 hours. From when I remember doing mine, it took about 20-30 min or so to do. I did mine at a shop on Laidlaw - that's when I had access to a lift after hours
    Aug 06 2008
    Canadia
    if the shop has the proper tools it shouldn't take 2 hours and $200
    the B5 S4 is like the mafia... there is only one way out!
    Veteran Member Four Rings CONTROL ONE's Avatar
    Sep 19 2008
    2014 BMW M235i 6MT, 2010 Audi S4 6MT
    Toronto, Canada
    Hmm, I've wondered about my fuel filter as well since it's never been replaced.
    Is there a rule of thumb as to when it should be swapped? My B5 S4 has 140k on it now.
    Established Member Two Rings xsbaiz's Avatar
    Sep 21 2007
    Audi 1.8T
    t dot
    If you can just do it yourself
    hope this helps
    http://www.audizine.com/forum/showthread.php?t=224783
    You Have To Pay To Play !
    Aug 06 2008
    Canadia
    that dosn't look too bad, on my B5 its a huge PITA
    Veteran Member Four Rings BNZ TOY's Avatar
    Oct 29 2006
    1G FX35, 03 R6, B6 A4 MT6
    Vancouver
    it took my shop about 30 mins to do mine.
    His name is Jun at Tekam. Call him at 604-430-6404. Tell him Ben with the silver A4 sent you. He just did mine about 2 weeks ago. Tekam in in bby near Imperial and Kingsway.
    Good luck.
    Another silver B6
    Go/Stop: K04-015 ~ Intake/TIP ~ Forge Splitter ~ Neuspeed turboback ~ B&M SS ~ H&R Sport w Bilsteins ~ S4 Sways ~ Eurocode FMIC ~ 245 Rotors/18z ~ FX300 240mm LWFW ~ Snow Meth Inj ~ EURODYNE tune
    Flair: USP Front ~ Cupra R ~ S4 Trunklip ~ Euro Roof Lip ~ VMR v710 235/19/35 ~ S4 doorblades ~ B7 rear valance ~ LED fogs ~ B7 DTM skirts ~ Euro RS4 Steering Wheel ~ S4 Recaros
    Jul 31 2008
    04 Audi 1.8T
    Markham Ontario
    Quote Originally Posted by BNZ TOY View Post
    Good luck.
    Where are you BNZ TOY. I am in Toronto. Looks like you are in BC.
    Thanks
    Sep 13 2007
    04 Atlas Grey A4 1.8TQ Avant
    Quebec, Canada
    In my case it took the shop around 1 hour because the darn clamps wouldn't get off. I had tried doing it myself and was not able to get those f_k_n things off.
    FXK03 - Stasis SS Coilovers - Forge DV - Forge TIP
    Oct 29 2006
    Vancouver
    Quote Originally Posted by Sammer55 View Post
    Thanks
    Opps, sorry Sammers. well, good luck anyways. YOu can do it yourself, it's just a bit messy and the clamps are a PITA to remove.
    Another silver B6
    Dec 14 2008
    2002, B6 A4 1.8T 5 spd
    I replaced my filter in 15 minutes, remove the shitty plastic gaurd opposite the rear pass tire, youll need two hose clamps for the lines , remove lines and install new filter, this is if you have access to a lift, my tuner let me use his for free, ask yours, in favour , purchase a bottle of octane booster from him to justify the use of the lift. Cheers
