The project is going forward but I just realized that there are 2 different type of headlight installed on the A4: Xenon & Halogen.
Xenon: Correct me if I am wrong, with the Xenon, you have a switch inside the car (I am asking because I have it) that allow you to turn the DRL ON & OFF. Do you all have the switch? If not, are the DRL ON all the time?
Halogen: With this type of headlight, you don't have DRL. Am I correct? I am planning to use the wires from the city lights but for the LED to work, you will have to turn the switch to the CTL position. Do you see a problem? Would it be a problem for you?
Thank you for your comments
