Results 1 to 20 of 20
Thread: Clunking Noise
    Veteran Member Three Rings Drew-B6's Avatar
    May 15 2008
    Syracuse, UT
    Clunking Noise
    Ok, I am getting a clunking noise from the front passenger side when breaking. Could this be a bad ball joint? Any ideas before I take it in?
    Drew-
    2013 Audi S4
    Veteran Member Three Rings Killerteve's Avatar
    Nov 09 2006
    02 A4 1.8TQM
    SF
    Re: Clunking Noise
    When I had a clunking sound it was because the subframe bolts where loose, though this was not a braking issue. Just thought I'd through it out there.
    REVO GT2871r Elim - 034 - Southbend - Racetec - Forge - HID's - RS4 reps - Podi - APR Snub - Tein - Genesis - Neuspeed
    May 15 2008
    Syracuse, UT
    Re: Clunking Noise
    When did you hear your clunking noise? Mine happens when I am slowing down and then I hear a single clunk! It doens't happen everytime but alot.
    Drew-
    2013 Audi S4
    Registered Member Two Rings
    Sep 18 2006
    vancouver
    Re: Clunking Noise
    Me too...
    Anyone know what happened?
    Veteran Member Four Rings downhillracer's Avatar
    Aug 20 2007
    97 Jeep Wrangler
    Costa Mesa / Mammoth Lakes
    Re: Clunking Noise
    you guys are gunna have to do some visual inspections...look at all your control arm bushings and tug and pull on parts... grab your tire top and bottom (with the car off the ground) and push on the top and pull on the bottom then vise versa and if the ball joints are bad you will feel movement.
    Veteran Member Four Rings trueno429's Avatar
    Aug 02 2007
    B6 1.8TQ 71R 6SPD
    BK,NYC
    Re: Clunking Noise
    ^^ he's telling the truth, "i tell you!"
    Veteran Member Four Rings chadb2434's Avatar
    Oct 07 2008
    East Texas
    Re: Clunking Noise
    that really crazy because myne is doing the same...every sence I got my tires rotated...
    02 A4 3.0Q6MT
    -chad
    Veteran Member Four Rings Audi Skate Snow's Avatar
    Mar 31 2004
    C300 Sport and tools
    CA
    Re: Clunking Noise
    clucking noise when braking or accelerating usually is a CV Joint. That is my guess, but hard to tell with out more info or diagnosing it.
    look in by your wheel and see if there is a shit load of grease in there. most the time when the CV joint is bad the boot tears and shit gets everywhere.
    BetaAlphaTau member #1.5
    R.I.P B6 A4!!!!!! 12/03/2005 12.63@108... stock 1.8 motor W/ GTRS.
    B6 A4 Avant, 2.0 Liter, 3071, Maestro
    Aug 20 2007
    97 Jeep Wrangler
    Re: Clunking Noise
    Quote Originally Posted by chadb2434 View Post
    Then its one of your tires! swap the two front tires and see if it pulls the other direction!
    Senior Member Two Rings geoshu's Avatar
    Feb 20 2008
    '03 A4 1.8T Quattro
    Vancouver, WA
    Re: Clunking Noise
    Quote Originally Posted by Killerteve View Post
    Same exact issue here, alignment shop charged me $30 to torque all my subframe bolts, fixed the issue immediately.
    Senior Member Two Rings WhiteA4's Avatar
    Feb 29 2008
    South Texas
    Re: Clunking Noise
    My 03 audi started doing the same...
    Its just randomly , when I brake .. I hear and almost feel a clicking
    , like a load creak when I brake , ussually i can hear it towards the
    front on the passanger's side feet area.. Sometimes I swear I hear it close
    to the center console . but It 's a noise defenitely coming from the passanger area?
    Should I replace the control arms, ball joints on the passanger side.
    What about the subframe, I heard they can crack in the welds, thus causing the clicking ( creaking noise)
    Veteran Member Three Rings Monkey77's Avatar
    Oct 30 2007
    2005 Audi A4, Tiptronic.
    new jersey
    Re: Clunking Noise
    Quote Originally Posted by WhiteA4 View Post
    Dude, I am having the same exact noise, checked my CV joints, and no cracks or leaks..............
    " You can't be lucky all the time, but you can be smart everyday."
    Feb 13 2009
    AUDI Q7
    Toronto DT
    Re: Clunking Noise
    changed pads twice b/c of that i thought pads are shitty...but still trying to figure out.
    but thing is I don't hear any noise when pressing on brakes.
    Senior Member Two Rings wickedrick's Avatar
    Mar 11 2008
    2004 quattro 6MT - kawasaki
    Montreal
    Re: Clunking Noise
    How many time will I have to say this on AZ
    if you have a poping noise when coming near to a complete stop... chance are 99% your front subframe is shot !!
    it should clunk more easely when your coming to a stop on a step hill downward !!
    R.I.P. Totaled- 2004 Ocean Blue F4H Stage 2+ 6 speed quattro ... OEM+ approved // EUROKARTEL.ca Montréal
    Agence web Montréal
    Annonces classées Québec
    SEO Expert Montréal
    Senior Member Two Rings mlchael4's Avatar
    Jan 12 2009
    '02 A4 1.8t Sport Package
    West Burbs, IL
    Re: Clunking Noise
    Add me to the list.
    I have been searching this subject for a while now..and can't seem to track down the cause.
    Inspected under the car and along the backside of the wheels, nothing unusual there.
    I still need to pull the wheel well liner and inspect a little further, but am looking for some direction.
    Mike
    Veteran Member Four Rings Pufftrees's Avatar
    Mar 10 2009
    B9 RS5, B9 S4, 8V S3, B5 S4
    New Jersey
    Re: Clunking Noise
    The subframe bolts should be an easy check, get a long prybar and a socket and torque those bad boys down, if you hear the clunking when turning/braking it could very well be a CV (this is like the 4th cv post i have had today wtf)
    Cheap and fast wont be reliable.
    Reliable and cheap wont be fast.
    Reliable and fast wont be cheap.
    Veteran Member Three Rings 03a4sport's Avatar
    Nov 14 2006
    Noblesville, IN
    Re: Clunking Noise
    Do people not check out there own car before posting on here? I swear. Who brings back old threads anyways.
    Like stated earlier, get the DAMN car in the air people.
    I had the same issue/sounds coming from front of my car. Popped/clunked when I stopped, started, turned, sat in my car, looked at it funny. You know what I did, put it on jack stands. Now if you don't have a jack, borrow one. Wiggle the $hit outta your tires and see if the car makes any noises. No? Then try this one, with car in the air, crank the crap out of your steering wheel and see if the pop starts with that. If that's the winner, steering column. Learn how to adjust for steering lash and fix your problem. Doesn't work, new steering rack and search for DIY, it's been done before.
    Still no luck, subframe, suspension, etc....
    Look under your car and see if you have a dead squirrel up there too. Post pics if so.
    Quote:
    Originally Posted by B6driver
    its suppose to scoop up air, not snow... too much air + missing screws = dragging pan at 70 mph and people behind you scattering when the pan flies off
    ____________________________________
    Current: 2010 B8 S4 Prestige DSG / Roc Euro Intake / 034 Transmission Mount Insert / Ebay LED interior lighting
    Wrecked by someone paying attention to their Iphone and not the road: 2006 S4
    Sold: 2003 A4 1.8TQM
    Mar 10 2009
    New Jersey
    Re: Clunking Noise
    Quote Originally Posted by 03a4sport View Post
    F*cking dead squirrels, I had one gnawing on my timing belt last week.
    Jan 12 2009
    West Burbs, IL
    Re: Clunking Noise
    Are you serious??
    What's wrong with asking questions about a thread/topic that has already been started? At least people are using the search function and not creating new threads before researching.
    What difference does it make if the thread is brand new or 10 years old...
    There will always be someone looking for a little help with any one of the problems we all experience, that is the purpose of this site is it not.?.
    Mike
    Nov 14 2006
    Noblesville, IN
    Re: Clunking Noise
    There's like 15 "Clunking noise" posts on the first page. If people can't read, I don't have a problem with them posting sorry.
    http://www.hookedonphonics.com/
