    Nov 17 2008
    A4 crankshaft AWM change to AWP
    I need the information:
    Can I replace the crankshaft from AWP engine (VW BORA 1.8T 2003) to my 2001 A4 Avant AWM engine?
    Is that the same crankshaft in this engine?
    Oct 27 2007
    2001 Golf 2004 A4 USP
    In the lab
    Re: A4 crankshaft AWM change to AWP
    Manual to manual crank, yes
    Dec 05 2007
    I do not know how much funds are going into this project. But if you are doing engine work, I would also look into doing rods and pistons at the same time.
    Courtesy of 317ssayzarc
    For drop in solutions you have the AZG and AEG cranks. The AEG and AZG are from MK4 2.0’s and are cast in construction.
    Full write up here
    You could easily get AEB forged pistons (used in good condition can always work) and Scat rods. Or keep the stock pistons and get Integrated Engineering Rods. Just a suggestion!
    Feb 27 2005
    North Wales, PA
    Quote Originally Posted by 317ssayzarc View Post
    i think all transverse cranks are the same..no?
    Feb 27 2005
    North Wales, PA
