Originally Posted by
edkwok
I researched on it before.
Our cars should be 1-2 degree on camber when lowered.
It shouldn't be that bad if tires are rotated regularly and drive hard on corners.
When you say "on' camber I'm assuming you're suggesting negative camber,
as in the top of the tires are closer to the engine then the bottom of the tires?
like they're tilted inward slightly? I'll have to check and see where mine are at, as the alignment guy was lecturing me that it's crazy to be rolling that way
and that my tires won't last 5k miles.!!! They didn't give me the info on the setup as they did the work for free. Maybe that's why he was pissed
Anyways, I'm still going to look into it and watch the wear.
Anyone else out there actually running an ACA or anything like it?
Can MacGyver make something for me?
