    Established Member Two Rings midnyite's Avatar
    Jun 28 2007
    Oil leak from turbos but no smoke k04!!
    If there is oil coming from the turbo, but no car does not smoke whatsoever. what does that mean? does it mean the turbo is going bad or somehting is loose causing the turbos to leak oil externally. There was also oil found in the intercooler as well.
    Any help is appreciated
    Aug 06 2008
    Canadia
    Re: Oil leak from turbos but no smoke k04!!
    bad seal/loose
    the B5 S4 is like the mafia... there is only one way out!
    Jun 28 2007
    so is that somehting that can be fixed? do i have to remove the engine to have it fixed?
    Veteran Member Four Rings S4 in_lowplaces's Avatar
    Feb 09 2006
    2021 SQ8, 2000 AWE stg 3 s4, 2012 CTSV 730Whp, Sold: 2000 Stg2 S4 revo,Totaled: 2000 Stg1 S4 APR
    Huntington Beach
    yes your turbo is going bad if its leaking oil. You might have a loose oil feed line or return line which just needs to be tightened. But tyipically if your finding oil in the intercooler and the amount your finding, then its going bad,
    2021 Ocra blk SQ8 - Daily
    2011 CTSV coupe 730 WHP - Garaged
    2000 Silver B5 S4 AWE stg 3 - Garaged
    2002 Silver b5 s4 stage 2 revo - Totaled
    2001.5 silver apt stg 2 b5 s4. - Sold
    Veteran Member Three Rings NogaroWonda00's Avatar
    Jun 13 2008
    Rocky Mountains
    It sounds like a lose oil line, if you take off your lower IC hose and rub your finger on the inside and you get oil on it, then your turbo is going...
    any smoke out the exhaust?
    '00 Nogaro Blue S4
