Results 1 to 23 of 23
    Registered Member Two Rings
    Sep 06 2004
    MD
    asa ar1 18"..... opinions..
    searched.. but..
    what do you think abou the wheel....
    i have hp evo 18" now..
    don't like the quality much...
    thinking about changing it to asa ar1.....
    http://www.tirerack.com/servlet/Call...filterSpecial=
    please let me know..
    Veteran Member Four Rings skene's Avatar
    Feb 13 2004
    Las Vegas
    do you think you're going to like the quality of that wheel as well?
    you get what you pay for.
    2017 Toyota 86
    Sep 06 2004
    MD
    i hear you....................... Thanks..
    Oct 18 2004
    2001 VW Jetta 1.8T
    Piscataway, NJ
    I haven't heard too many bad things about ASA wheels. I mean they are "licensed by BBS". I'd say they are probably a step up from the HP wheels, if anything...
    Sep 06 2004
    MD
    i c... that'z what i m thinking too.. little better than hp...
    i m just regreting about buying hp orinially..
    with the money saved up. i could get the better one..
    well..
    too late.. so.. just help me out here...........
    as far as looking and licensed by bbs.. it's pretty appealing..so..
    infos. please........Thank you very much..
    Feb 13 2004
    Las Vegas
    this is what I think.... keep the HPs.... deal with it.... see how you like it in a year from now... do other things to the car in the meanwhile.
    2017 Toyota 86
    Sep 06 2004
    MD
    u think so? skene.. humm.. i might do that.. since i like the look of hp better than asa........
    Veteran Member Four Rings pdxa4's Avatar
    Mar 26 2004
    12 Golf-R, 03 S8, 08 GTi, 06 MX-5
    Austin TX was San Jose, CA
    ASA wheels have a pretty good reputation...they are good value also...
    Current: 12 VW Golf-R, Rising Blue
    Former: 03 S8, Ming Blue
    Former: 08 GTi, 4dr DSG
    Current: 06 Mazda NC MX-5 many mods
    Former: 03 B6 A4 Avant 1.8TQ
    Former: 00 B5 A4 1.8TQM J31-K04
    Former: 04.5 Euro Passat PD TDI
    Original PDX
    V1.0 Member since 02/24/2002
    Matrix Integrated**
    Sep 06 2004
    MD
    i really don't know what to do....
    i think the hps i have causing little vibration and air sounds somehow..
    i dont' know wheather i change it or not..
    than again i cannot afford good one yet.. so.. asa?
    need more info..please.
    Jun 09 2004
    Massachusetts
    I seem to remember learning that ASA's are generally heavy. Maybe 'cuz they're cast. Of course, it would depend on the style, size, etc.
    If weight is a concern, check with TireRack before you buy.
    Registered Member Four Rings audlman's Avatar
    Apr 19 2004
    04 SRT-4
    louisville, ky
    linky doesn't work, it said session expired???
    Veteran Member Four Rings sumpsfast's Avatar
    Apr 02 2004
    '92 UrS4 - Black
    Denver/Chi-town
    Wierd for a wheel to cause air sounds. The vibration may be from hitting big potholes or something. That HP wheel I believe is an ADR product. Supposed to be a good wheel for the price. Weight is like 22-23 (18"). It does look good as well.
    Registered Member Four Rings jesseahhstyle's Avatar
    OC, California
    Or the vibration is as simple as a tire out of balance, how could all of you not think of that? Seriously. To add to it ogi lay off so many periods, complete your sentences before you need to have a period. I understand your typing as you think.
    Just save the money and apply it elsewhere.
    Sep 06 2004
    MD
    Thanks for your advice jesseah, i did wheel balance three times actually and got sick of it but still the vibration.
    so, you recommand re-adusting tire by taking off and putting on again? if that helps i will try do that.
    one more thing, is there certain way to balance the wheel?
    OC, California
    Do you have weights on the inside or the outside of your wheel?
    There are 2 types of balancing your tires, static and another way. But I forget. Your wheel could be bent also... Make sure the shop is doing it right. Your alignment could also be off also causing a vibration.
    Veteran Member Four Rings offroader1006's Avatar
    Oct 17 2004
    77 International Scout II, 98 XK8, Tahoe, XC90
    Columbia, SC
    many times the actual tire may be bad or cheaply made which can cause vibrations just as an out of balance wheel would.
    and you cant balance it out
    Sep 06 2004
    MD
    i have weight on both outside and inside,
    and i didn't do alignment because the place where they do alignment told me that i don't need to do it.
    should i just do the alignment? or is it the two weight balance thing.
    Thank you very much for all your insights
    Oct 17 2004
    Columbia, SC
    alignment should not cause a vibration,
    its all in the rotational masses (wheels and tires)
    Veteran Member Four Rings quattro_maniac's Avatar
    Aug 29 2004
    2001 Audi A4 1.8T Quattro
    middletown, nj
    read the second line...Licensed by BBS....
    ASA are just a cheaper version of BBS wheels...they are basically the exact same units, just not the same price
    ASA AR1
    BBS RS-GT
    i dont see a huge difference...
    WorkSafeBoredom
    Mr. Blonde
    Borla - GFB - BFG - Flik - RedLine
    "The American dream really is fucked." - Hunter S. Thompson
    Registered Member Three Rings awe4rings's Avatar
    Feb 18 2004
    Fairfield County, CT
    go asa save the $
    -awe4rings
    Veteran Member Four Rings e.van's Avatar
    Mar 09 2004
    1999 A4 Avant 1.8T quattro, 1976 BMW 2002
    Cleves, OH
    GET THE ASA'S. They look awesome on our cars, and my AR1's are indestructible. I can't even begin to explain how many times I should have blown tires and bent my rims, but they come out looking brand new still. They're a lot better quality than you might expect...
    1999 Cactus Green A4 Avant 1.8TQM
    Black DEPO eCodes | 3000K & 4300K HIDs | City Lights
    Dual-Rear & Front Fog Mods | 1-Touch Windows
    LLTek Mesh Grille | 710 N | Dump-Truck Exhaust
    OEM B6 5-Spoke Wheels | Neuspeed Race Springs
    I think it's obvious that I don't care how fast my car is.
    Veteran Member Four Rings quattroanillos5's Avatar
    Feb 13 2004
    2004 S4 MT6
    Jersey
    are the BBS forged?
    sold:
    1999.5 B5 A4 1.8T quattro MT5
    current:
    Moro Blue 2004 B6 S4 MT6
    Registered Member Three Rings C280 jr's Avatar
    May 12 2004
    Chicks Car
    Atlanta -LW
    e.van, post more pictures please
    Elvir
    dürtydübs
    clean cars, dürty people
