No codes showing- but strong fuel smell- running rich. Much more noticable since fixing the cam adjuster gasket leak- burning oil smell is now gone.
All hoses appear in good condition.
APR 93 OCT program
New MAF.
Checking on O2s- when I run block 32 they seem to be with parameters. Never see more than 1.9 and 4.9. Current file shows 1.3 and 2.3. Never see it change much and no negative numbers- always positive.
This data below was on a drive to dinner after warm- couple hard runs to 5000 rpm. I do not see the values changing- can someone verify this is OK.
I did check block 15 and 16- I get a couple of misfires on cylinder 2. 3-4 depending on how long I run.
PLan to check for vac/boost leaks again this weekend- but replaced all leaking hoses and check valves.
What else to look at?
Group C: '032
Adaptation (Idle) Adaptation (Partial)
TIME Bank 1 Sensor 1 Bank 1 Sensor 1
STAMP % %
0.47 1.3 2.3
1.02 1.3 2.3
1.57 1.3 2.3
2.12 1.3 2.3
2.66 1.3 2.3
3.18 1.3 2.3
3.73 1.3 2.3
4.3 1.3 2.3
4.83 1.3 2.3
5.36 1.3 2.3
5.91 1.3 2.3
6.42 1.3 2.3
6.93 1.3 2.3
7.47 1.3 2.3
7.98 1.3 2.3
8.51 1.3 2.3
9.02 1.3 2.3
9.56 1.3 2.3
10.1 1.3 2.3
10.61 1.3 2.3
11.14 1.3 2.3
11.66 1.3 2.3
12.19 1.3 2.3
12.7 1.3 2.3
13.26 1.3 2.3
13.8 1.3 2.3
14.34 1.3 2.3
14.88 1.3 2.3
15.44 1.3 2.3
15.99 1.3 2.3
16.55 1.3 2.3
17.09 1.3 2.3
17.63 1.3 2.3
18.18 1.3 2.3
18.71 1.3 2.3
19.26 1.3 2.3
19.8 1.3 2.3
20.35 1.3 2.3
20.88 1.3 2.3
21.4 1.3 2.3
21.91 1.3 2.3
22.44 1.3 2.3
22.95 1.3 2.3
23.49 1.3 2.3
24 1.3 2.3
24.55 1.3 2.3
25.07 1.3 2.3
25.61 1.3 2.3
26.15 1.3 2.3
26.68 1.3 2.3
27.2 1.3 2.3
27.73 1.3 2.3
28.27 1.3 2.3
28.83 1.3 2.3
29.36 1.3 2.3
29.91 1.3 2.3
30.44 1.3 2.3
30.99 1.3 2.3
31.53 1.3 2.3
32.06 1.3 2.3
32.62 1.3 2.3
33.16 1.3 2.3
33.68 1.3 2.3
34.22 1.3 2.3
34.74 1.3 2.3
35.27 1.3 2.3
35.81 1.3 2.3
36.36 1.3 2.3
36.9 1.3 2.3
37.45 1.3 2.3
37.98 1.3 2.3
38.49 1.3 2.3
39.07 1.3 2.3
39.6 1.3 2.3
40.13 1.3 2.3
40.64 1.3 2.3
41.18 1.3 2.3
41.72 1.3 2.3
42.25 1.3 2.3
42.77 1.3 2.3
43.3 1.3 2.3
43.84 1.3 2.3
44.38 1.3 2.3
44.92 1.3 2.3
45.45 1.3 2.3
45.97 1.3 2.3
When I goto OBD and select O2 sensors- it only reads the S2 back one. The S1 does not read- is this VAGCOM issue or indication of bad O2?
I know too many qustions in this stream of consciousness.
