Results 1 to 3 of 3
    Veteran Member Three Rings 02B6's Avatar
    Nov 05 2007
    Toronto, Canada
    Winter Tire Question**
    ok so i currently have 17 sports. I wana put on steelies, due to the function of the steel wheel. Canadian winters sometimes arn't too pleasant. I found a set locally, but the size is 205/55/16 which includes 16" steelie. They came off of a 98 (B5)A4. So i am guessing a 5x112. The seller doesn't know too much about them. From what I gather the bolt pattern should be the same. The thing im not too sure about is the tire dimensions. I am lowered, and dont want to lose sidewall.
    Any advice.?
    Thanks,
    Adam
    2002 (B6) 1.8TQM...H&R - S4 Spoiler - 6k HID - open cone filter - Forge Splitter - avic d3 - podi/SW
    Established Member Two Rings Plasticar's Avatar
    Jul 08 2008
    B6 A4Avant, B5.5 Passat 4mot
    West Bloomfield, MI
    Re: Winter Tire Question**
    The rims will fit, yes they are 5x112. The tire is slightly smaller, as the B5 used 225/45-17 while B6 used 235/45-17. It should be 4.5mm in sidewall height less. It's not the end of the world, but it is not the true correct size, either.
    Veteran Member Four Rings Mark's Avatar
    1959 MGA 1600
    Chocolate Land, USA
    Quote Originally Posted by Plasticar View Post
    I run 225/45 R17's on my winter tires, 235's on my summer ones.
    OP, more sidewall in winter tires is optimal along with slightly thinner tires. 225 vs. 235, in my case.
    -Mark
    1987 5000 CS TQ 2.2T I5 - No more . . .
    2002 Denim Blue A4 1.8TQMS - RIP
    2005 Ebony Black Pearl allroad 2.7TQMT6
    Kinda stock . . . Tinted, H-Sport Sways, HP-2 Calipers, RNS-E, Bluetooth, and iPod/Sirius combined
    Got Vag-Com?
