Results 1 to 22 of 22
Thread: redline?
    Senior Member Three Rings a4mafia(Red)'s Avatar
    Nov 06 2008
    B5 A4 1.8tqm
    Cincinnati
    redline?
    hey, i just wanted to know what RPM you shift at with all the big turboed 1.8ts on here....with upgraded rods and pistons? whats safe?
    thanks, justin
    work in progress....
    B5 A4 2.8 FWD Transmission:
    http://www.audizine.com/classifieds/...ct=9554&cat=12
    Veteran Member Four Rings JumboBlack1.8's Avatar
    Sep 16 2006
    '98 528i
    Boston/West Hartford, CT
    Re: redline?
    Unless you've done head work, u don't want to rev any higher than you normally do. The stock head cannot handle it....I'm running a BAT on a stock bottom end (for now) and I don't shift higher than 7krpms on a WOT run...I normally shift around 6.5k
    I plan on doing some head work in the spring, and I'd like to raise my rev limit to 8k rpms
    *important*
    Head work is just as important as a built bottom end if you are building a high HP BAT 1.8T
    2000 Audi B5 S6 ** 4.2L 40v S6 6spd - http://www.audizine.com/forum/showth...n-s6-4-2L-swap
    Oct 27 2007
    2001 Golf 2004 A4 USP
    In the lab
    Re: redline?
    On the stock head, 7500 is safe... In a motor with upgraded springs 9000 is safe... Thats the limit on hydro lifter heads, if you go solid you can go to whatever you want, but its not worth it imo...
    Keep in mind you can rev high with springs, but it takes a LOT of other headwork and supporting mods to make power up there
    Feb 15 2008
    E46 323i 5-Sp
    616/MI
    Re: redline?
    Quote Originally Posted by 317ssayzarc View Post
    What he said. If you want some fancy head work, take a look into http://qedpower.com/. That's an idea of what a "fully built" head will cost you. ... all that for 8.5K+ rpms.
    Once you're limited on velocity in the head, you must increase volume. Audi switched to the small port heads for a reason, velocity (at least that's my understanding)
    Apr 22 2007
    Riverbank, Ca
    Re: redline?
    7.2k Thats where I shift, because thats where my max power is at... And my rev limiter...
    However im not BAT, im just APR stage 3 (and some stuff).
    Registered Member Three Rings kovalevandrew's Avatar
    Oct 19 2008
    South Africa
    Re: redline?
    9000.......? Oh yes please!
    Aug 14 2008
    Salt Lake City, UT
    Re: redline?
    I would save 9000-9250 for GOOD springs and upgraded exhaust valves ONLY. I would stick to low 8000's with stock exhaust valves or cheap "upgraded" springs. That's a lot of hammering on those sodium filled exhaust valves!
    supertech spring / retainer kit or cat golds ftw.
    Integrated Engineering LLC
    Your source for fine quality VW/Audi Connecting rods and engine hard parts. Applications including: 1.8t, 8v, 10v, 20v, V6 and V8...
    www.intengineering.com
    Oct 27 2007
    In the lab
    Re: redline?
    I suggest doing the exhaust valves at 350chp or more...
    Nov 06 2008
    B5 A4 1.8tqm
    Cincinnati
    Re: redline?
    hmmm. interesting....i just asked bc i saw a video of a gtrs kit with only rods(as far as interals go) reving to 8500 rpms...thanks
    Aug 14 2008
    Salt Lake City, UT
    Re: redline?
    I do too... That is the first thing I recommend people change in their heads. IMO it's best to replace the ticking time bombs first, other stuff later.
    rods, exhaust valves.....
    Jul 07 2004
    630AWHP A4, Nissan Titan
    socal
    Re: redline?
    Quote Originally Posted by a4mafia(Red) View Post
    Well that turbo really doesn't make much power at anything over 7k, so taking it to 8500 is pretty pointless.
    Apr 22 2007
    Riverbank, Ca
    Re: redline?
    Thats what I thought as well. Dont know why someone would want to rev that high.
    I'd like another .3k rpm so I dont always shift AT the limiter (I hit it once in a while, especially in first). Or in an autox situation a lot of times you dont want to shift and want to just ride out that gear...
    Nov 06 2008
    B5 A4 1.8tqm
    Cincinnati
    Re: redline?
    it actually pulled all the way through 8k. but after that it didnt do much.....
    Jul 07 2004
    socal
    Re: redline?
    Yes it pulled to 8k but that doesn't mean its actually making more power after 6500 rpm where that turbo is going to hit peak hp, from there it drops like a rock.
    You can rev a K03 to 7200 but it isn't making as much power as it does at 5k rpm.
    Here is a dyno of the Elim kit. As you can see it peaks at 6k and is decreasing after that. Even at 7k rpm it would be making the same power as it does at 4500, at 7500 it would be equal to what it makes at 4k. Believe me taking it past 7k doesn't make the car faster.
    BTW its called talking it out of the power band. If I did that while drag racing my ET's would end up much slower.
    Nov 06 2008
    B5 A4 1.8tqm
    Cincinnati
    Re: redline?
    yeah, it was noticable that it didnt pull as fast at 7500 rpm.....but if he reved higher, when he shifts to the next gear wouldnt he start out higher in his powerband?
    .....how do you think your car would do against a stage 2 or 3 s4?.....you have the negaro a4 2.0L with the carbonfiber hood and trunk on youtube right?
    Sep 16 2006
    '98 528i
    Re: redline?
    lol
    Mike's car is a dedicated track car. He sets records for not only A4's, but for the B5 platform in general. To compare his car to a stage 2 or stage 3 S4 is just child's play......lets get serious. He's not in it for youtube fame
    I believe that last week he broke his 10.6 1/4 mile time at the track running a GT35 on a built 2.0 (just to name a few things)......i think you may need to read a lil more in the archives of this forum to learn about what these cars can really do. A nicely build 2.0 with a BAT (imo that stands for a GT30r and up), they'll hold up with and even beat stg 3 s4's on the road and the track (but shhhh, don't tell S4 owners....they get mad) Youtube doesn't tell the story. Research, my friend.
    *edit*
    and its pelican blue, not nogaro
    I know you mean well (not bashing), but definitely try to take advantage of ALL the information this sight has to offer every day, and in the archives which are accessed by using the search function [thumbup]
    Nov 06 2008
    B5 A4 1.8tqm
    Cincinnati
    Re: redline?
    Quote Originally Posted by JumboBlack1.8 View Post
    lol
    *edit*
    haha i figured he wasnt in it to youtube fame ...but i have seen stage 3 s4's beat lamborghini's(SP?)
    i'll start searching in the archives right now
    ...pelican or nogaro, its SICK!
    Dec 20 2007
    1999.5 Audi A4qm AEB
    iowa
    Re: redline?
    I'm not a fan of the color. Mikes car is like the chick you do want to tell everyone you had sex with but never forget because it was that good. Well lets just keep it at I'm not a fan of that color but the car is sick.
    Jul 07 2004
    socal
    Re: redline?
    There isn't an S4 in this country that has ran below 10.7, the only one to do that was fully gutted to 2500 lbs with the driver in it. It didn't have a dash, door panels or window motors. Basically it was just a shell with a driver seat. Next fastest S4 in the country was the Eurocode that ran 10.8 with me in the driverseat.
    When you can find a S4 in this country that can run 6.8 at 107 mph in the 1/8th mile, mid 1.5 60 ft times and 0-60 in less then 3 seconds let me know.
    BTW most of my vids are on Streetfire.net. You might also want to check the A4 and S4 times on Dragtimes.com
    Nov 06 2008
    B5 A4 1.8tqm
    Cincinnati
    Re: redline?
    i dont read about s4's as much, but your car is very impressive and im not going to doubt it . i've seen cars on dragtimes.com before, they're somewhat vague on their description of the car sometimes, but i'll look you up on streetfire.net
    Dec 20 2007
    iowa
    Re: redline?
    Sorry Mike no offense I was drunk.
    Nov 06 2008
    B5 A4 1.8tqm
    Cincinnati
    Re: redline?
    Quote Originally Posted by Toyotatech View Post
    hahahahahahah
